sdnatlst (5th July, 2019)
What obd mcu 256 ?12 bytes cs akl? Dreamer
We donk know what is plate 57![]()
immoneard (6th July, 2019)
Great thanks! yes 2007 car ,
sorry i have never removed EZS so had no idea what MCU or EEPROM it had inside!
now i know its OBD job, so i can tell customer i can do it![]()
Tools owned -
Don't say, until you have done it![]()
p1et (5th July, 2019)
Tools owned -
You have to read ECU and get 6 byte CS and pin. Then go to AUDI Key menu , find A6/Q7 , enter manually CS and Pin, Prepare dealer key, then program it , Everything in same menu.
If key buy form Dealer , then no need prepare dealer key, just program it after you you put 6 CS and Pin.
yugo45 (4th August, 2019)
hi,how to change remote data filles in vvdi2?
Hey. Who can explain this to everyone? There is no English, only Chinese? Or maybe there are some settings to fix this?
MVVL (7th July, 2019)
As i told you before guys, the problem is with vvdi2 learning keyless key system (color tft 2013 dash),
The customer take the car to dealer they re-adapt for him the key with online and the keyless system is working now in both key the old ori and the new ine
Envoyé de mon SM-G973F en utilisant Tapatalk
Hi , can VVDI2 transmit immodata from one BCM2 to another BCM2 (Audi 2010,2012) Thanks
