Page 415 of 553 FirstFirst ... 315365405410411412413414415416417418419420425465515 ... LastLast
Results 6,211 to 6,225 of 8286
  1. #6211
    Aug 2015
    BEHIND YOU
    please fix add key by dump
    to mercedes ML AAM and EAM... because i get always error
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  2. The Following User Says Thank You to eliaselias For This Useful Post:
    ruffles1986 (8th July, 2019)
  3. #6212
    Oct 2016
    France
    Quote Originally Posted by eliaselias View Post
    i have the same problem,i did say it about 2 months ago but nothing change,i do you use another tool for old mercedes
  4. #6213
    Apr 2016
    Quote Originally Posted by barho67 View Post
    these errors are many many that will never be solved, for example, xhorse released new product named vag obd helper, which can collect data for audi bcm2 all key lost internal can data collect for vvdi2, in case that vvdi2 should be able to do it self, but can not, always error
  5. The Following 3 Users Say Thank You to K1nd3r For This Useful Post:
    immoneard (8th July, 2019), sniegavirs (8th July, 2019), super jumbe (8th July, 2019)
  6. #6214
    p1et's Avatar
    Oct 2013
    I ordered some CAS4/FEM BMW 868MHz keys from autokeys.us. Is it possible to change their frequency to 315MHz? Someone have access to those PCB keys to look? I'd like to know before I order 315MHz from them next order.
  7. #6215
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by p1et View Post
    I will check tomorrow.
    But for me in EU. 90% of cas4 is 868
    90% of fem/bdc is 433.
    And key 433 from autokeys.us can work with both cas4 and fem/bdc.
    With Tapatalk
  8. The Following 3 Users Say Thank You to didi_du_93000 For This Useful Post:
    barho67 (8th July, 2019), kronk92 (15th March, 2020), p1et (8th July, 2019)
  9. #6216
    p1et's Avatar
    Oct 2013
    Would be nice, thanks. I have customer with 5 series USA so I need 315MHz and I heard keys from autokeys.us are 100% reliable and working on cas4/fem both that's why I ordered from them
  10. #6217
    Feb 2014
    Quote Originally Posted by didi_du_93000 View Post
    With Tapatalk
    Not exactly - for 433 you have to specify if you need it to work for FEM or you need it for CAS4. They are not compatible like on 868 and 315 mhz.
    This is only for 433mhz. And I heard there is a way to distinguish them by the exact MHZ they are working on:
    - if it is 433.9mhz then it should be key for CAS4 system which has EWS4 level of security;
    - if it is 433.2mhz then you can use it only on FEM/BDC system, which is also called CAS4+ with EWS5 level of security.
  11. The Following 2 Users Say Thank You to autoTkey For This Useful Post:
    sniegavirs (11th July, 2019), super jumbe (12th July, 2019)
  12. #6218
    Will vvdi2 change kilometers in Passat B8 via OBD?
    Will vvdi2 change kilometers in Passat B8 via OBD?Will vvdi2 change kilometers in Passat B8 via OBD?
  13. #6219
    Quote Originally Posted by lem2 View Post
    As there are several types of dashboards, there is no clear answer on it.
    Continental/VDO regular dashboard yes
    JCI no -> only Baracuda with partnumber 3G0 920 741
    Magnetti Marelli by dash coder
    Virtual cockpit / AID no tool at all
  14. The Following 2 Users Say Thank You to exe123 For This Useful Post:
    immoneard (12th July, 2019), lem2 (12th July, 2019)
  15. #6220
    Apr 2016
    uk
    Can someone help me with an Audi A6 2012 akl please...
  16. #6221
    yugo45's Avatar
    You have to take out Steering lock and read EVL .
  17. #6222
    yugo45's Avatar
    We can just keep dreaming, this problem is old over 2 years and never been fixed.
  18. #6223
    Apr 2016
    uk
    Quote Originally Posted by yugo45 View Post
    Yes did that..
    I have bcm2,elv,ECU files.
    Car still turn ignition but not start.
    I need to connect to can but gearbox is manual not CVT .
  19. #6224
    Apr 2016
    uk
    these are all files...
  20. #6225
    Apr 2016
    uk
    Anyone done a 2012+ Audi A6 akl ?
    Vvdi2 is asking to connect on internal canbus.
    Has 2 options,with CVT gearbox or without.
    For cars without CVT gearbox there is no explanation where I have to connect.
    Anyone can advise please where to connect on canbus on this car?
