Page 416 of 553 FirstFirst ... 316366406411412413414415416417418419420421426466516 ... LastLast
Results 6,226 to 6,240 of 8287
  1. #6226
    Apr 2016
    Anyone done a 2012+ Audi A6 akl ?
    Vvdi2 is asking to connect on internal canbus.
    Has 2 options,with CVT gearbox or without.
    For cars without CVT gearbox there is no explanation where I have to connect.
    Anyone can advise please where to connect on canbus on this car?
    this should be understood as not supported
  2. #6227
    Apr 2016
    uk
    Quote Originally Posted by K1nd3r View Post
    There is a video with flyobd doing an a6 2012 akl.
    If not fake, vvdi2 should do it..
    Have you tried akl on this one?
  3. #6228
    Apr 2016
    last time i leavet a6 with ignition/remote ok, no start, gearbox locked while transponder writen not fully, engine ecu was continental
  4. The Following User Says Thank You to K1nd3r For This Useful Post:
    comizelu (13th July, 2019)
  5. #6229
    Apr 2016
    uk
    Ecu is Bosch edc17c46 in this one.
    Gearbox manual.
    I have key to turn on ignition (with safe on dash) and remote working as well.
    Bcm2,elv,ECU data-i read everything..
    Last step,internal can bus...
    For CVT gearbox they added 3pictures where to connect and is just the plug from abs pump.
    For not CVT gearbox they added one poor picture without any explanation what to do..
  6. #6230
    Apr 2016
    Gearbox manual.
    i think internal can monitoring procedure need only for gearbox data check, if manual do not need
  7. The Following User Says Thank You to K1nd3r For This Useful Post:
  8. #6231
    Apr 2016
    uk
    Well,for A6 AKL,the third step si to connect to internal can and is asking if gearbox is CVT.if press YES will tell you to connect to abs plug.if press NO will tell you to connect to another plug but can't find it,not described.
    I think is mandatory to connect to internal can.. thanks
  9. #6232
    Sep 2016
    Try connect to abs then.
  10. The Following User Says Thank You to qeso705 For This Useful Post:
    comizelu (14th July, 2019)
  11. #6233
    Apr 2016
    Quote Originally Posted by qeso705 View Post
    orange/blue or orange/red it is same wiring, same can
  12. #6234
    Apr 2016
    uk
    Does not work.
    Tried to connect and vvdi2 "can't connect,make sure gearbox is CVT - automatic".mine is manual.
  13. #6235
    Oct 2016
    France
    can vvdi found pin code from citroen xsara if key is not adaptet to this car(new transponder) ??
  14. #6236
    jodge's Avatar
    Mar 2017
    No. Working key required.
    If the bcm/bsi whatever is NEC based then it's soldering job. If later model then maybe lonsdor able to read via OBD
    The best way if you read it from the ECU
  15. #6237
    Oct 2016
    France
    Quote Originally Posted by jodge View Post
    ok thanks,usually i take pin from ecu,but in this old shit have old sagem ecu with rouber inside so its not possible to do on this ecu,i will try from bsi
  16. #6238
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by barho67 View Post
    Be careful with the bsi. Most of them are water damaged craps (the cable from the engine bay is providing some water into the bsi) with badly aged cables and connectors. It could be a nightmare...
  17. The Following User Says Thank You to jodge For This Useful Post:
    barho67 (16th July, 2019)
  18. #6239
    Oct 2016
    France
    yes i now it,thanks, this is French touch))
  19. #6240
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by eliaselias View Post
    please fix add key by dump
    to mercedes ML AAM and EAM... because i get always error
    On these the only good guy to do these correctly when does not work correctly with your programmers is to ask member Addick .
    I think the trick is in closing the data on the key when you program it to the transponder ....
