Page 418 of 553 FirstFirst ... 318368408413414415416417418419420421422423428468518 ... LastLast
Results 6,256 to 6,270 of 8282
  1. #6256
    Apr 2016
    uk
    Quote Originally Posted by crazylou2017 View Post
    Please provide your original car key picture, if it is IMMO 4th generation, VVDI2 can work; if it is IMMO 5th generation, it depends on the engine ECU.
    It's immo 5.
    Engine ECU edc17c46...
    2.0l diesel
    Manual
  2. #6257
    sdnatlst's Avatar
    Aug 2011
    England
    Can we do 2018 year passat ? Spare key
    Tools owned -
  3. #6258
    May 2016
    hello every one
    dash jhonson controle cant be done
    "msg error :this option in futur"
  4. #6259
    Is it possible to add key to Porsche 996 with VVDI2?
  5. #6260
    Jan 2017
    MSS60 still does not work reading isn from dme.
    I checked on the latest version 6.6.0.
  6. The Following 2 Users Say Thank You to kkkkamil26 For This Useful Post:
    immoneard (23rd July, 2019), yugo45 (22nd July, 2019)
  7. #6261
    Anyone knows if this is already compatible with g-30 bdc?
  8. #6262
    May 2018
    hello can you help me i have the upa i need to read the opel tms370 antenna but l donīt have the adapter can connect via up cables help i have months trying
    hello can you help me I have the upa I need to read the opel tms370 antenna but I don't have the adapter can connect via upa cables ?????? help i have months trying
  9. #6263
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by battistini1 View Post
    Carprog by OBD very easy.
  10. #6264
    Apr 2019
    Hello. After VVDI2 update did BMW X1 F48 spare key. BDC system. Everything was as usual in the begging but got problem during flash process. Got error "Upload part (2/2): Failed. It failed at 46%. So I'm thinking now, why this happened to me? VVDI2 was updated recently (6.6.0V). Also it might be my fault. By accident I set current limit on the adjustable power supply up to 1.1A and forgot to increase to the max - 5A as usual.
    Now interesting why this happened? During flash process current consumption is usually up to 0.75A when ignition is on. Voltage was 13.8-14V. Maybe during flash process on the part 2/2 within the range 40-50% vvdi2 restarts BDC unit and at the same time it activates relay or something who could briefly and instantly increase current consumption? Now I'm confused a bit, want to know why this happened.
  11. #6265
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Amperage on this job just bit above 0.5 amp. 1 amp not issue
  12. #6266
    Apr 2019
    Hmm, now it's a bit more clearly, just now I looked again at the picture, I see error at the bottom of the window "Failed to initialize device..." Somehow vvdi2 device lost connection with laptop during flash process. Maybe someone had same problem? not the first time I did spare key, all the time everything was fine before vvdi2 update. I must mention that I didn't move device or anything during flash.
  13. #6267
    Feb 2014
    It could be a Windows issue...
    Is it all fine with the drivers?
  14. #6268
    Apr 2013
    hello good I tried to read several instrument panel audi a3 8p from 2004 and I have not been able to read any with reference 8p0920930, put select a3 tt, and a screen comes out that connects the ignition and I am not able to read it
  15. #6269
    Jul 2019
    Quote Originally Posted by torero233 View Post
    Audi A3 2004-2005 with Fujitsu is not supported in VVDI2, Only with Micronas 2006 and up.
  16. The Following 2 Users Say Thank You to immoneard For This Useful Post:
    torero233 (28th July, 2019), yugo45 (4th August, 2019)
  17. #6270
    szengen's Avatar
    Jan 2017
    super chip-toyota h
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
