mercedes vito could i read immobox then i load file to vvdi2....i get transponder error.....
i used 25$ zedbull and generate same transponder and car start well
also same issue with mercedes ML aae eam....it should be fixed this issue from long time
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
VVDI2 v6.6.1 version release CAS4/CAS4+ OBD programming function. Support all CAS4 with CPU XEP100(5M48H, 1N35H). No need online, no need soldering, Please update ASAP!
"Nice work"
u.s (20th August, 2019)
damih (20th August, 2019), ThiagoArgentino (20th August, 2019), u.s (20th August, 2019)
Who will be first test rabbit? F series waiting to be bricked.
didi_du_93000 (20th August, 2019), p1et (20th August, 2019)
RG550 (20th August, 2019)
Be the man. Do it without dump backups. Only real man do it by obd
amigokola (20th August, 2019), barho67 (20th August, 2019), Fallen (27th August, 2019), ghostrider72 (20th August, 2019), p1et (20th August, 2019), sniegavirs (28th August, 2019), sqlkarol (21st August, 2019)
bmw 120 d ,2006 year. add key is it safe to do with VVDI2 by OBD.
triak88 (21st August, 2019)
must i put battery charger
It should be standard CAS2 / CAS3 so this should be very straight forward 2 minute job without need of battery charger.
