sniegavirs (22nd September, 2019), super jumbe (21st September, 2019)
VVDI BMW blue box is up for preorder at 1000$
Xhorse VVDI BMW Highlights:
1. Support E chassis/F chassis Programming function
2. Support E chassis/F chassis code function
3. OBD key Key: Support CAS1/CAS2/CAS3/CAS3+/ISTAP/ etc.
4. File Generation Key: Supports CAS1/CAS2/CAS3/CAS3+/ISTAP/CAS4/CAs4+, etc.
5. Support FEM/BDC system to generate keys, replace FEM/BDC control unit, support reset mileage
6. Supports mileage correction CAS1/CAS2/CAS3/CAS3+/ISTAP/CAS4/CAs4+
7. Support for reading EEPROM and sync data for CAS1/CAS2/CAS3/CAS3 systems
8. Support simultaneous engine and CAS, synchronous ELV and CAS
9. Support reading SN data from the engine
What's the difference between VVDI2 BMW and VVDI BMW?
VVDI BMW not only for locksmith, it has functions of coding and programming and much more.
VVDI BMW has possibility for manual coding and changing cars vo (vehicle order) , emergency flash and retrofit options.
A4 B8 2015 - vvdi2 add key?
castin (22nd September, 2019)
Ok, other Way to add key using vvdi2 or anoother tool?
Client sey car its 12.2014.
2019 golf mqb hu66
Add key is OK with vvdi2?
Spare key
Tools owned -
Yes pretty straight forward
Hello mates, I think it’s a bad question but need to ask you if it’s possible to use vvdi2 sotfware with fvdi2018 that have vvddi2 inside the launcher ?
Thanks in advance
Remember thanks and reputation buttons if helped
that the engineers working at xhorse do not forget why they were created, reliability and equipment are not bad,
the equipment for this money is good, we can always point out mistakes
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
Any way to clone mqb id48 remote key?
With Tapatalk
didi_du_93000 (24th September, 2019)
