Jimmy07 (11th December, 2019)
I tried to read a Bosch MED 17.5 from an 09 VW Passat. It connects, but will not crack the security. I emailed xhorse about the issue and was told they don't have the password for some of these. This is the tricore 1766 processor.
Thanks for your reply Comizelu 👍🏻
This is the first cluster I’ve changed can I pick your brain for a few answers please
Steps:
1. Read and save ABS coding old cluster
2. Read and save immo data old cluster
3. Put new cluster into service mode
4. Fit new cluster
5. Load immo data to new cluster
6. Start car & test
Question is this what’s needed to put new cluster into service mode ?
Jimmy07 (12th December, 2019)
No don’t have key for new cluster
It’s the step/steps to put into service mode I’m not clear on. Is it just a button or is there a procedure?
If there is a fault or problem with new cluster will old one still work and start car etc. ( works now just problem with rev counter )
Sorry for questions haven’t had this tool long and don’t want to balls this job up
Cheers 🍻
Brilliant thank you for taking time out to do this 👍🏻👍🏻👍🏻👌
If its a problem with rev counter why don’t you just replace motor on it?
Ghostrider it’s a job I’m doing for a car spark they have the new cluster and want it fitted/adapted I’m just doing what I’m told on this one. So a case of what they want they’ll get.......
Q5 2015 is something we can do between vvdi2 and bag obd helper?need a spare key..
Yes, its possible.
comizelu (12th December, 2019)
Can't set super chip using vvdi2.
Anyone tested with latest software version?
EDIT: used another laptop and it worked fine.
thank you, just to corroborate vvdi reads SOME ecu's ISN thru OBD and some others I'll have to use vvdi prog or ktag to extract ISN. is this correct?
also I don't have vvdi prog but which other equipments compliments this device in order to work more efficiently.
Sent from my SM-N950U using Tapatalk
Hi. In latest update v6.6.8, device connected Ok, but sincronizacion with server ERROR. I try several times, but nothing. I cant use the soft in nothing.
Any solucion??
NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
