YOU MUST INSTAL ALSO THE SOFTWARE V6.6.8
torero233 (20th December, 2019)
perfect has already been solved thank you very much
lechus111 (21st December, 2019)
Hi i have pernament DTC internal fault on CAS4 after unlock by OBD2 V668. Fault cant delete. No backup cas4 with programmer
I have vvdi2 full ver.6.6.5I tried to clone Ford key but could not do it, I was writing on regular 4D chip, not vvdi super chip.
Can VVDI2 clonechips the same way like VVDI Key Tool?
Thank you.
no ,you can not use normal 4d chip , for clone function ,always need to use the xhorse chip ,which means super chip now ,
I'm a new user of vvdi2 and that's why I ask in the forum to encode the transponder. It's not written in the manual.
I'll buy a super chip and try the option.
It is important to me that the function works.
Thank you
lechus111 (23rd December, 2019)
already. Try now
vvdi2 should have cas2 in the list !!! You have to downgrade CAS3 + !!!
I think vvdi2 shit!
is somebody enegineer for vvdi i have some problem with the tool ??
Did somebody did audi q7 2013 add key (banana key).
It fails to auto detect cs and pin from engine ecu.
Is it save to read thru obd J518 to get cs and pin, or need to take out and read on the table ?
