Page 466 of 548 FirstFirst ... 366416456461462463464465466467468469470471476516 ... LastLast
Results 6,976 to 6,990 of 8219
  1. #6976
    Feb 2020
    I never done any cas4 on car and I won't do them,same as cas3+.
    If you do these by obd it's your choice. Everyone is free to choose how to do them. My friend had extra power on car too..and ...
    I think one problematic CAS is the one with elv.
    ok how do i know wich cas has elv? can i read on the cas numbers? i see that one without is 322 with elv is 323 ... this soldering thing is a bit risky too or not?
    what if you burn eeprom or something else? what about this eeprom clip is reading ok? i m new in this vvdi programing keys i m waiting to arrive i bought vvdi2 and prog with clip and some adapters. have a lot of experience in doing other cars and cas2 and 3 also without+ version but now i m expanding my knowlege to vvdi and cgdi .. bought cgdi for benz cars and vvdi2 and prog for bmw audi new toyota ...
    But i really dont want to brick the cas i saw on forums you can update cas then with e-sys or winkpf trough enet cable if car doesnt start?
  2. #6977
    Feb 2020
    and i saw video with doing cas4 on bench but no soldering just with cas4 test platform .. is it safer? they claim that it is ..
    https://www.youtube.com/watch?v=lRoPM7CID9o
  3. #6978
    BRASIL / SUL
    vw jetta 2016> 24c64 5c6920876, can you pair with engine ecu? ? and after that can you generate a new key? i want to know if vvdi2 does for this model.
  4. #6979
    t77's Avatar
    Poland Lodz
    Hello friends,I have question for more advanced users of VVDI2 . Is possible add key with function KEYLESS to Audi Q7 4th immo generation 2009y ?
    THX for any advice
  5. #6980
    Apr 2016
    uk
    Quote Originally Posted by t77 View Post
    THX for any advice
    From where did you bought a keyless key?
    And ..Yes , why not?
  6. #6981
    t77's Avatar
    Poland Lodz
    Hi from market ,not from Audi dealer,but new one .not used.This is link http://www.kluczeluban.pl/klucze/audi.html
  7. #6982
    castin's Avatar
    Oct 2015
    Audi A6 2014 ADD keyless key (used renew by Barracuda) - vvdi2 work OK?
  8. The Following User Says Thank You to castin For This Useful Post:
    musti418 (25th February, 2020)
  9. #6983
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by castin View Post
    yes work 100% work
  10. The Following User Says Thank You to rola1971 For This Useful Post:
    castin (24th February, 2020)
  11. #6984
    Sep 2013
    Still not solved..
    Subaru Justy 2002 add key (immobox same as suzuki swift)
    All key lost. I need help to add key to immobox 33970-60G03 subau justy 2002
    Tris 4C key: 00 00 7E 39 48 78 80 00 00 00 00 3B 9A 7E 00 00
    00000000011E129C
    In attachment working key from donor immobox need rewrite to ori immobox.
    I make it by my self but not sure if it will work. (car is faraway)
  12. #6985
    Jul 2019
    Make sure you can read that BCM2 , most cars 2014 and up not possible to read BCM2 since that locked.
  13. #6986
    Quote Originally Posted by immoneard View Post
    It can, i made mine and is 2016 my
    Enviado desde mi SM-G975F mediante Tapatalk
  14. #6987
    rola1971's Avatar
    Jun 2014
    Dublin
    same time no posibility read in vvdi2 bcm2 but i used vag helper and it is work 100%
  15. The Following User Says Thank You to rola1971 For This Useful Post:
    castin (26th February, 2020)
  16. #6988
    Mar 2018
    UK
    On Barracuda use V6 for unlock on other versions LED blinking without touch the buttons
  17. #6989
    Nov 2018
    Bamako
    Hello
    I bought vvdi2 but it is only in Chinese. Unable to change the interface to English. do you have an idea
  18. #6990
    Jun 2017
    US
    Anyone done range rover sport Cem and wrote to super chip without having to write back to cem? Tried to write a new chip in as well to unused 3rd slot, but didn't have any chips, so cloned a 46 off a new ebay flip key with Handy and tried to write that in. Neither worked, but this is my first cem akl, not sure where it went wrong. Does this dump look okay?
    https://drive.google.com/open?id=14g...rWQ5kprvW7uJzH
    or different link
    https://easyupload.io/yym6bm
    This is dump after adding in 3rd key.
