immoneard (22nd May, 2020)
Hello does anyone tried to read and write
isn of edc16c35 Bmw e70?does it work correctly.
Sent from my SM-J415F using Tapatalk
Hello.
I have such a problem. I did a counter swap on the VW Caddy 2k5 2016. Everything according to the procedure (dump eeprom, service mode, I swapped org eeprom through obd, then security block from my car) and almost everything
The car starts, zero errors on the meter but the brake assistant does not work.
In the assistant (address 13) is a component protection error. The same error is in the counter (but the counter can be cleared and returns only when I start, for example, change the comfort option using maxi dot).
Does VVDI2 not copy CP from counter to counter?
Is it possible that only the ODIS online option remains?
I have a VAS head but before I buy online access I would like to use all the possibilities. I also have the original carprog and Polish Xtool.
I am asking for a hint.
greetings.
manfred2 (29th May, 2020)
I do not understand.
At the moment I have a copy made with the programmer from the second (before adding) counter and the immo data from it, a copy of the eeprom (by obd) of my old counter) and immo data.
What should I write?
Provide my forum dumps?
greetings.
Cas3+ is safe over OBD AKL and spare? Should I be benching these?
darknezz19 (29th May, 2020)
Xhorse VVDI2 Upgrade
Software Update to V6.7.5
Release Date
2020-05-28
Requires firmware upgrade to V6.7.5
What’s New
VAG V6.7.5
1. Improvement for autodetect VAG immobilizer system
2. Improvement for update FRF, SGO file
3. Bugfix
BMW V6.7.5
1. Improvement for CAS3 key learning
2. Bugfix
Transponder Programmer V6.7.5
1. Improvement for make proximity remote
2. Immobilizer data tool:Asia->Hyundai->Santa Fe->2008-MPC5XX bugfix
3. Improvement for clone ID70/ID83
4. Special chip: Add new ID47 for GreatWall ORA
5. Bugfix
Copy 48 (96 bits) V6.7.5
1. Bugfix
J2534 V6.7.5
1. Bugfix
Online Upate Tool V6.7.5
1. Bugfix
Quick Start V6.7.5
1. Bugfix
Download Link
https://public-ap-southeast-1-125105...tallerV675.exe
TERMINATOR1000 (29th May, 2020), ThiagoArgentino (1st June, 2020)
I have a 2012 BW Kessy cluster 7N0 920 870 E, H03, SW 0607 and I want to change in a color cluster 7N0 920 880 N, SW2030
I copied the Immo Block with VVDI 2 into the new cluster, my problem is that when I transfer immo data to a new information panel and install it in the car, the dashboard does not turn on at all.When I press the tart button, the alarm lights do not come on at all and I cannot connect via PC
Could someone help me with right configuration?"
Hey. On the new version, the program does not detect the device. Install back the old version everything is OK. Installing drivers, as in a help, does not help. What kind of problem? Or is it just me?
