Page 501 of 551 FirstFirst ... 401451491496497498499500501502503504505506511 ... LastLast
Results 7,501 to 7,515 of 8262
  1. #7501
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Quote Originally Posted by offsystem View Post
    not keyless System
    but how to fix this?
    Gesendet von meinem SM-G986B mit Tapatalk
    You Can Force Ignition By Make A Bridge In The Keyless Entry Module Connector That Is To Be Found Under The Plastic Cover Right Below The Steering Wheel,
    Post A Picture Of The Plug, To Identify Which Version,
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  2. #7502
    Oct 2018
    Northern Ireland
    A blown 5 amp fuse can cause screen to go black
  3. The Following User Says Thank You to Jimmy07 For This Useful Post:
    PremierD (11th January, 2021)
  4. #7503
    not keyless System
    Try disconnect the car battery and reconnect again after a few minutes!
  5. #7504
    Jul 2018
    CHINA
    Quote Originally Posted by dimet View Post
    How to use this option?
    you need activate that license first ,then buy one id48 collector , and also in the software it will guide you step by step
  6. #7505
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Does anyone have any info where and when will be available to buy Xhorse XM proximity remote keys?
  7. #7506
    Jul 2018
    CHINA
    still not yet ,it will start sell in china and test it ,
  8. The Following User Says Thank You to PerryZhang For This Useful Post:
    sniegavirs (11th January, 2021)
  9. #7507
    Aug 2020
    Seat Alhambra /2007 AKL
    I tried to read the pin with vvdi2, I have read the pin and sc from ECU. With the pin I try to learn new key, vvdi2 reported that the key is learned but the car is not starting, after that I try to add new key with vcds but vcds reprted that the pin is not correct. Any help is much appreciated!
  10. #7508
    ghostrider72's Avatar
    Jul 2012
    UK
    Did you precoded it first?
  11. #7509
    Jun 2013
    Quote Originally Posted by nikovali View Post
    Partnumber Cluster?
  12. #7510
    Oct 2016
    Slovakia
    I assume the dash is a visteon
    Connect a dump from the ECU and a new scb from the dash
  13. #7511
    Aug 2020
    Quote Originally Posted by Weasel3 View Post
    Partnumber Cluster?
    7M7920840Q VDO V46
    ECU-EDC15xx
  14. #7512
    Jun 2013
    You make TP22 first ?
    And only use PIN ?
    Sure you read the exactly right number on the engine ECU ?
    Try to read Km at the same time. And compare with what cluster says.
    It might need precoding with 7bytes, you only get 6 out of the engine ECU.
    So the last pair could be a hazzle to sort out.
    Could it be more a Ford part this one. Not the usual look of a VAG cluster.
  15. #7513
    Aug 2020
    VVDI2 read ECU EDC15xx
    PIN 01134,CS:57 62 D5 9F 67 41 A5
  16. #7514
    mikajna's Avatar
    Mar 2015
    Alhambra is like Sharan, it should be transponder pcf7935 prepared as VW ID44.
    Good luck
    Послато са SM-A505FN помоћу Тапатока
  17. #7515
    Jun 2013
    This is what the list says:
    SEAT ALHAMBRA 2000-2003 PHILIPS Crypto ID44 PCF7935AS (VAG precoded)
    SEAT ALHAMBRA 2003-2006 Crypto 48 ID48
    SEAT ALHAMBRA 2006-2010 MEGAMOS Crypto-SEAT precoded TP22
    Check you VIN production date of the vehicle.
    You must test in VCDS if key is accepted - mod25,mea_block08, then chose block_001. This will tell you if key is accepted, to be programmed.
    With ordinary TP22 or precoded as well.
    And off course PIN needs to be accepted.
    And also check lock time. If so, might need to stay with ignition ON. Connected to a charger quite a long time. To count down the minutes. This is visible in VCDS.
  18. The Following 2 Users Say Thank You to Weasel3 For This Useful Post:
    mikajna (13th January, 2021), nikovali (14th January, 2021)
