Page 502 of 551 FirstFirst ... 2402452492497498499500501502503504505506507512 ... LastLast
Results 7,516 to 7,530 of 8261
  1. #7516
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by Weasel3 View Post
    This is what the list says:
    SEAT ALHAMBRA 2000-2003PHILIPS Crypto ID44 PCF7935AS (VAG precoded)
    SEAT ALHAMBRA 2003-2006 Crypto 48 ID48
    SEAT ALHAMBRA 2006-2010MEGAMOS Crypto-SEAT precoded TP22
    Check you VIN production date of the vehicle.
    You must test in VCDS if key is accepted - mod25,mea_block08, then chose block_001. This will tell you if key is accepted, to be programmed.
    With ordinary TP22 or precoded as well.
    And off course PIN needs to be accepted.
    And also check lock time. If so, might need to stay with ignition ON. Connected to a charger quite a long time. To count down the minutes. This is visible in VCDS.
    That list is not always true, its not hard to try that to, or to see if there is immo box behind cluster. I would try transponder id44 honestly.
    Послато са SM-A505FN помоћу Тапатока
  2. The Following User Says Thank You to mikajna For This Useful Post:
    Weasel3 (13th January, 2021)
  3. #7517
    p1et's Avatar
    Oct 2013
    There is no ID48 in Sharan / Alhambra. All use ID44. That list above confuse many people.
  4. The Following 4 Users Say Thank You to p1et For This Useful Post:
    immoneard (30th January, 2021), mikajna (17th January, 2021), sniegavirs (13th January, 2021), Weasel3 (13th January, 2021)
  5. #7518
    Newbie danis11's Avatar
    Sep 2012
    Latvia
    Where is problem? Read original transponder wich come with Seat.
  6. #7519
    Apr 2016
    uk
    Quote Originally Posted by danis11 View Post
    It's all keys lost..
    Definitely id44
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  7. The Following User Says Thank You to comizelu For This Useful Post:
  8. #7520
    Sep 2012
    Latvia
    Definitely id44
    Where is it said?
    And it is also possible and necessary to look at the data of diagnostics for the compatibility of transponders with our eyes, if there is no confidence in compatibility.
  9. #7521
    Apr 2016
    uk
    Where is it said?
    Seat Alhambra 2007 AKL !
    Read his first post.
  10. The Following User Says Thank You to comizelu For This Useful Post:
    danis11 (14th January, 2021)
  11. #7522
    Sep 2012
    Latvia
    I read AKL as engine type. Write such abbreviations in non-capital letters!
  12. #7523
    didi_du_93000's Avatar
    France Paris
    Polo 2013,
    1.6 tdi with pcr2.1 ecu.
    AKL.
    Can't do it because vvdi2 will search pin cs from ecu motor, and this ecu is not listed.
    Spvg solve me this fastly,
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  13. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    Weasel3 (18th January, 2021)
  14. #7524
    Apr 2016
    uk
    Quote Originally Posted by didi_du_93000 View Post
    Polo 2013,
    AKL.
    If it AKL ,pin and cs from ECU doesn't help much.
  15. #7525
    Dec 2016
    HELPER VAG BY OBD2 , it's an new tool ! AKL for 5$
  16. #7526
    Jul 2018
    CHINA
    yes , get data online it is good way for AKL ,
  17. #7527
    France Paris
    Supervag original in 15minutes.
  18. #7528
    Apr 2016
    uk
    Clocks out?
  19. #7529
    ASCM's Avatar
    Oct 2018
    Polo 2013,
    AKL.
    Supervag which steps used to program key
    Sent from my 5033F using Tapatalk
  20. #7530
    Mar 2018
    UK
    What Xhorse keyless key must be generated for Fabia 2015 keyless?
