Page 514 of 555 FirstFirst ... 14414464504509510511512513514515516517518519524 ... LastLast
Results 7,696 to 7,710 of 8323
  1. #7696
    Jan 2016
    Russia
    he is not declared there. I'm talking about autel
  2. #7697
    ASCM's Avatar
    Oct 2018
    Hello does anyone tried to program transponder for kavasaki Moto with vvdi 2
    Sent from my 5033F using Tapatalk
  3. The Following User Says Thank You to ASCM For This Useful Post:
    p1et (12th May, 2021)
  4. #7698
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by ASCM View Post
    test copy/clone 4D chip of kawa, work ok with superchip
    many thanks to friend kevfield
  5. #7699
    Feb 2014
    I couldn't complete a Caddy 2017 PQ add key job with AES transponder.
    VVDI2 acts as it has some bug. It is also very possible that I didn't use VVDI2 correctly but X300 OBDSTAR also could finish it.
    Car has one working key MQB 48 and VVDI2 detects as "NEC+24C64 2014.06-". I read and backup EEPROM and IMMO and move on to make the OEM Dealer key. When I check working key position it detects it as "FFFFFFFC" and says it's not from this car. I read it in other device and compare the ID and select the other one but then VVDI2 returns another odd message - "Failed to set OEM key ID! Make sure the input key is not locked!". I used XSMQB1EN and generated it with few different MQB options from Key Tool software but never got to pass these messages. I also tried to make normal Dealer key but got the same message when tried to do it.
    What did I do wrong?
  6. #7700
    Apr 2016
    uk
    Quote Originally Posted by autoTkey View Post
    User fault!
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  7. The Following User Says Thank You to comizelu For This Useful Post:
    autoTkey (17th May, 2021)
  8. #7701
    Feb 2014
    Got it, I'm an idiot ...
    Edit: Yep - client just returned to finish the job. I actually used the IMMO dump from the other day to generate the OEM dealer key before he arrived. Car started straight on with it. No any additional programming was required (except for adding of the remote).
    I'm curious - what other cars have this modification? I know already about Caddy, Transporter, Jetta, Sharan, Alhambra ... any other?
  9. #7702
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by daxxer View Post
    It's all key lost situation
  10. #7703
    dimet's Avatar
    MKD
    New update
  11. The Following User Says Thank You to dimet For This Useful Post:
    u.s (21st May, 2021)
  12. #7704
    But how do you update? Using the update tool, seems to be updating, but all versions stay the same.
  13. #7705
    dimet's Avatar
    MKD
    Quote Originally Posted by nemena View Post
    https://www.xhorsevvdi.com/info/free...are-12141.html
  14. The Following 3 Users Say Thank You to dimet For This Useful Post:
    immoneard (21st May, 2021), nemena (20th May, 2021), TERMINATOR1000 (21st May, 2021)
  15. #7706
    ASCM's Avatar
    Oct 2018
    tested not work
  16. #7707
    Land rover, generate a key without write the dump to the KVM.
    First key: Remote ok, but " no key detected" - most of the time.
    Second key: Start ok, but no remote at all. Actually give up.
  17. The Following User Says Thank You to qwojtus For This Useful Post:
    mikajna (23rd May, 2021)
  18. #7708
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by qwojtus View Post
    Which version of Landrover it is?
  19. #7709
    lion0304's Avatar
    Oct 2014
    From 2015 - 2018
  20. The Following User Says Thank You to lion0304 For This Useful Post:
    qwojtus (24th May, 2021)
  21. #7710
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by lion0304 View Post
    From 2015 - 2018
    You need to write generated data to KVM after that need to add by obd second remote
