Page 51 of 551 FirstFirst ... 41464748495051525354555661101151 ... LastLast
Results 751 to 765 of 8259
  1. #751
    Apr 2015
    Quote Originally Posted by philipcoin View Post
    today did renault clio 2
    not work security light not flash dump change complete i post dump to check this bug
    93c66, 8pin, 512 Bytes
    Renault: Clio (2001)
    friend,please write 'fixed_renault clio -11 key2 added.bin'data back,should be ok.next version will fix this bug.
  2. The Following 5 Users Say Thank You to Samic For This Useful Post:
    amigokola (22nd August, 2016), daxxer (18th August, 2016), philipcoin (18th August, 2016), PremierD (18th August, 2016), yugo45 (19th August, 2016)
  3. #752
    Nov 2014
    thanks samic
    will text and report
  4. #753
    May 2013
    Quote Originally Posted by LauAlf View Post
    Samic, Opel - Immo 2,
    created the chip, but the car did not take the chip, and even tried to set by OPCOM says invalid chip.
    A bug in the programming.
    Immo 2 I tried and writes but but when read chip on Zedbull still shows as "BLANK 7935". So seems they have a bug in IMMO 2. When I do it with EFFI works 100%.
  5. #754
    Nov 2014
    Quote Originally Posted by Samic View Post
    thanks samic
    it start one time
  6. #755
    May 2013
    Default VVDI 2 making tyransponder for A Class W168 Not Work
    Hi there guys and Hi SAMIC.
    I have a problem here on VVDI 2 with making transponder for Mercedes A Class W168 with 7935. When I open the 1D69J dump on VVDI it show all key "NOT USE". However customer had keys and lost it. Also on MB Star it show 2 keys registered. When I try to make transponder with VVDI then it writes chip, but car not start and show INVALID chip.
    I tried 2 or 3 other dumps and all on VVDI show all keys NOT USE. Only 1 dump show 2 keys but this dump from another vehicle so cannot use here.
    Is there some solution to this problem???
    I have attached few dumps for you to check. Please help me as it is urgent.
    A Class.rar
  7. #756
    Dec 2015
    Audi A6 2006 ESL fault
    Hi mates i've got audi A6 with ESL fault any idea how to fix this issue used esl can be adapted by vvdi2 obd or by eeprom swap any idea mates thank u
    NO ADVERTISING PLEASE
  8. #757
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by Nassreddine84 View Post
    If pcb faulty read old with xprog and copy eprom to the new one.
    If motor fault, simply swap the motor, but if it is not burned or heavily weared cleaning and regreasing can do the job
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  9. The Following User Says Thank You to lpf01 For This Useful Post:
    yugo45 (21st August, 2016)
  10. #758
    Dec 2015
    Hi mates i have mini 2012 lost key CAS3+ tried on vvdi2 everthing went ok got ISN from dme and also eeprom from cas and remote programmed successfully but car does not start i did one fault once vvdi asked me wether the car has been start or no i said yes and car has not started yet i thought maybe because of the low battery but i gave power to the battery and tried no joy remote functioning but a yellow key shown on cluster
    Any idea i tried sync cas with dme and also cas with elv failed to sync so now what to do any suggestion plz
  11. #759
    Sep 2013
    Try one more time with option "car not starting "
  12. #760
    Apr 2015
    Quote Originally Posted by obeids View Post
    checked the attached dump,from your eeprom cannot find any key info.VVDI2 display is correct.
  13. The Following User Says Thank You to Samic For This Useful Post:
    CaioW (24th August, 2016)
  14. #761
    Apr 2015
    please try to select blank key position with 7953 transponder,via ISN method make key.
  15. The Following User Says Thank You to Samic For This Useful Post:
    yugo45 (24th August, 2016)
  16. #762
    Dec 2015
    I did new fresh programming of the key and the car starts thanks samic for ur help
  17. The Following 2 Users Say Thank You to Nassreddine84 For This Useful Post:
    CaioW (24th August, 2016), yugo45 (24th August, 2016)
  18. #763
    CaioW's Avatar
    Oct 2015
    Everywhere
    If the remote works, you just need to syncronize the cas with DME. (or ELV dont remeber now)
    Try it.
    edit: you already tried. Hummmmmm keep trying until sincronize. HOw many times you tried?
    edit2: You already start the car. i'm sorry,
  19. The Following User Says Thank You to CaioW For This Useful Post:
    Nassreddine84 (25th August, 2016)
  20. #764
    Nov 2014
    hello
    i have mitsubishi endeavor 2006 key id61
    eprom 24c01
    all key lot i load dump to vvdi it says unknown version
    please can you check
    i upload dump here
    regards
  21. #765
    Apr 2015
    hello
    eprom 24c01
    i upload dump here
    regards
    thanks for feedback this bug,make a beta version for you.please PM me get it.
