replace with good used elv
Nassreddine84 (26th August, 2016)
Just read the ESL J518 by obd, if you have a working key.
Or with a programmer like xprog or vvdiprog.
1L59W or the 3L40KEEPROM 2KB
FLASH 128KB
And copy this in to the replacement part.
Make sure that u have the correct partnumber.
amigokola (31st August, 2016), Nassreddine84 (27th August, 2016), yugo45 (27th August, 2016)
Just ask guys who buy cars and sell them in parts.....
Ususally i get 1 or 2 key plus elv around 100 euro. From ELV dump i can unlock the keys so i have 2 new keys and an elv for sale
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
Hi Samic
Can you please check that logs. When copy immo data on Golf MK5 dash from pre 2006 car into after 2006. Shows me ERROR on display. I had to type all data down manually and make new keys and all worked fine.
2008 Fabia 2 instrument 5J0920810B cannot read eeprom. Also ECU Simos 9.1 same problem. Samic, please check the issue.
If I helped you know what to do..
Hi....
Seems the VVDI 2 has many problems with the Renault key modules. It codes keys to eeprom but all bytes are swapped. So can they please solve this problem. For the time being how do we manually swap the bytes? Is there any easy way instead of typing out again each and every byte?
Thanks Yugo but I can't agree with it mate. Did it plenty times and never had problems with it. Its not conversion to white clocks but just simple red-to-red clocks swap on mk5 platform. Like 2007 clocks going into 2005 car.
can vvdi2 pre code vw phaeton 2008 key?
touareg dealer key.jpgSThere is a keytool, that allows you to make dealerkeys with the known CS.
