Page 539 of 552 FirstFirst ... 39439489529534535536537538539540541542543544549 ... LastLast
Results 8,071 to 8,085 of 8273
  1. #8071
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by wuza View Post
    Did anybody had problem with VVDI2 and new version 7.3.1 on VAG vehicles?
    Tried yesterday on an VW up and key learning failed.
    Read eeprom and immo data ok. Make dealer key ok.
    Learn keys failed. Removed the version and reinstalled it new.
    Problem is the same...
    Following things have been strange:
    CS is only FFFF...
    Total key count: 6 sometimes 7...
    Key IDs: 1st and 2nd ok and the other ones FFFFF...
    so immo data is wrong
  2. #8072
    auto techniek's Avatar
    Mar 2017
    Known issue by VW Up MM5 cluster
    Immo data is corrupted. Had this issue many times
  3. #8073
    Feb 2014
    Interesting. And how do you fix it?
  4. #8074
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by auto techniek View Post
    When you do cluster MM, does vvdi2 notify you that the inmodata is not the real one? Or does it give you a similar message?
  5. #8075
    Apr 2022
    Germany
    Quote Originally Posted by Supas View Post
    In my case it didn’t gave me a message...
    after Auto detected tells you to try mm7 and two others nec dashes.
    Tried all of them which have been given as tip and it didn’t worked out.
    Only mm7 did worked out,but with wrong immo/ eeprom data...
  6. #8076
    Apr 2022
    Germany
    One thing that was also strange: I couldn’t learn existing key with pin code?
    Same message appears: key learn error...
    What tool do you use? Carprog?
  7. #8077
    Supas's Avatar
    Jun 2020
    The MM cluster with AES encryption is not the forte of this tool... many data shows ok since they are visible in the eprom, but the CS that are encrypted there does not go well... it is something to improve.
    Work with caution these clusters.
    If you need any real CS of these cluster send me eprom and flash readings and I'll see it.
  8. The Following User Says Thank You to Supas For This Useful Post:
    wuza (5th April, 2023)
  9. #8078
    Mar 2017
    Did you try to re learn original key with odis?
  10. #8079
    fred77's Avatar
    Jun 2019
    Assume bug copied from AVDI 2015+. I've just cloned original but don't know how AKL pans out
    Solidarity with Ukraine
  11. #8080
    Apr 2022
    Germany
    No... unfortunately I don’t have odis...
  12. #8081
    I have a dead VVDI2 o was stored in the case in working order after doing the last update!
    After a week i was going to use it and is completely dead...anyone had a similar problem?
  13. #8082
    joker01's Avatar
    Jan 2018
    as a new owner of this instrument or have any questions.....
    i see i have 3 options to add the key....
    in which situation should I use one instead of the other??
    Thanks in advance....
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  14. #8083
    Apr 2022
    Germany
    Quote Originally Posted by joker01 View Post
    I would take option #3 on your place.
    First read eeprom and immo data, save it both,
    after that make dealer key and learn it via 3rd option.
  15. The Following User Says Thank You to wuza For This Useful Post:
    joker01 (23rd April, 2023)
  16. #8084
    May 2023
    [QUOTE=jodge;3673330]Un pequeño tutorial
    Los chips 8C o Tk5561 son caros pero con el nuevo superchip vvdi puedes copiar si tienes al menos una clave.
    Pero puede hacer una llave cuando se pierden todas las llaves y las herramientas vvdi eeprom no son compatibles con el automóvil como Ford Ranger / BT50 (con MC68HC805P18)
    verifique la imagen adjunta (Gracias Sasika por el volcado)
    Attachment 651474[/CITA]
    NO SABES CUANTO TE LO AGRADESCO ME VOLVI LOCO CON ESTE PROBLEMA MUCHAS GRACIAS!!
  17. #8085
    sniegavirs's Avatar
    Mar 2017
    Latvia
    [QUOTE=Tomas4750;4540869]
    Quote Originally Posted by jodge View Post
    Un pequeño tutorial
    ​ENGLISH!!!
