Page 544 of 552 FirstFirst ... 44444494534539540541542543544545546547548549 ... LastLast
Results 8,146 to 8,160 of 8273
  1. #8146
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    No will not proigramm your key.
    If you got dealer key, geko online
  2. #8147
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by srt8 View Post
    Thank you. Now, where do I get the immo data? Which unit contains this info? And what about the synch?
    All this info is on this forum, just use search button, it's common knowledge if it's possible and how to do it, just spent some time reading.
    And btw. if you have key supplied by dealer, then aftermarket tools can't program it, you need dealer account so searching informations I meant above is useless but recommend doing it for future purposes.
  3. #8148
    Jun 2018
    Quote Originally Posted by p1et View Post
    My friend, tell me where to buy immo data and synchronization data for 5C?
    Previously, this work was done by VAG OBD Helper, but as you know, it does not work now. I would be grateful for a hint
  4. #8149
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by urshul View Post
    The best clue is: Look no further, your only solution is a dealer key and program with odis online. What you are looking to buy/get does not exist who sells it.
    Vaghelper also did not solve the problem if it was akl since it did not give you any synchronization. It was useful for making copies in 5C.
  5. #8150
    srt8's Avatar
    Nov 2017
    Thank you all, ODIS took care of my problem.
  6. #8151
    honingkoning's Avatar
    Dessert
    Vvdi2 and FEM obd unlock,
    Did someone test this,is it safe to use or better to do it in the old way.
    Wbr Adam.
  7. #8152
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by honingkoning View Post
    Wbr Adam.
    Vvdi2 don't do fem unlock obd
  8. The Following User Says Thank You to teerak2uk For This Useful Post:
    honingkoning (9th October, 2023)
  9. #8153
    Dessert
    Quote Originally Posted by teerak2uk View Post
    Is this only for the bimmer tool .
    But did someone test it on the bimmer tool,is it safe to use?
  10. #8154
    No tool can do FEM obd unlock, it is BDC which can be unlocked by obd
  11. #8155
    auto techniek's Avatar
    Mar 2017
    I ve Audi A6;from 2012 with all keys lost.
    Removed bcm en have no clue if this version supported bij xhorse. Need to know before taking ELV uit the car
    Verstuurd vanaf mijn CPH2359 met Tapatalk
  12. #8156
    Maartinj's Avatar
    Nov 2010
    0421 is not sescured bcm
  13. The Following User Says Thank You to Maartinj For This Useful Post:
    auto techniek (10th October, 2023)
  14. #8157
    Mar 2017
    Ok
    I assume it is obd work if unsecured?
    Quote Originally Posted by auto techniek View Post
  15. #8158
    Jul 2019
    Melbourne, Australia
    Ok
    That'll get you immo data by OBD but not sync. A6 requires sync data as well in AKL situations.
  16. #8159
    Mar 2017
    I see here there is no synch data used with Autel
    www.youtube.com/watch?v=aMdn0Bv-REs
  17. #8160
    Jul 2019
    I wouldn't trust this video bud. For a start he doesn't show dealer key production which is a mandatory step with any immo5 system, with the exception of A4/A5/Q5 and only with one tool which makes the car do the dealer key production with the key slot. Furthermore it's quite some time ago and I'd say this was just at the tail end of when Autel was pulling sync data from the VAG servers for you silently in the background. Every BCM2 A6 I've worked on has required sync data.
    Always be careful with Youtube videos, the magic of editing and having a working key off screen to grab sync data off can make the impossible seem possible.
  18. The Following 4 Users Say Thank You to Spiritech For This Useful Post:
    auto techniek (10th October, 2023), p1et (10th October, 2023), tepSIJA (28th October, 2023), wuza (10th October, 2023)
