Page 549 of 553 FirstFirst ... 49449499539544545546547548549550551552553 LastLast
Results 8,221 to 8,235 of 8290
  1. #8221
    Supas's Avatar
    Jun 2020
    So far I had no problems reading with vvdiprog clip. But I did struggle a lot to clean, sand the legs so that it reads.
    If you tried to desolder with hot air, the eprom may have been damaged.
    If so, I don't know the procedure to recover the FEM but I know it is possible to do so. Maybe someone can explain it.
    EDIT:
    This seems to be a solution to the loss of information
    https://www.digital-kaos.co.uk/forum...=1#post3763288
  2. The Following 2 Users Say Thank You to Supas For This Useful Post:
    neilp1990 (27th April, 2024)
  3. #8222
    Sep 2023
    wales/uk
    I managed to get it off with low airflow and have pulled data, just not sure if it's corrupted as first attempt of trying one. I have orderd a clip for future won't be attempting to remove one again, unless it's a damaged one and can practice with it. Thanks for that i will have a look into that forum.
  4. #8223
    Sep 2023
    wales/uk
    Car worked after writing file to new eeprom. Vvdi2 also let me correct the mileage.
  5. The Following User Says Thank You to neilp1990 For This Useful Post:
    wuza (3rd May, 2024)
  6. #8224
    Jan 2017
    is there now a "B" Version or let`s say a better Version of solderless Adapter for the Virtual Cockpits available?
    I had also the smoke problem like I`ve read in another forum...
  7. #8225
    Fallen's Avatar
    Quote Originally Posted by Tabaluga View Post
    Smoke problem? now i'm interested. What happened?
  8. #8226
    Jan 2017
    I used XDNP81 and it worked sometimes and sometimes not and sometimes I had electrical smell and some smoke. But it read the VC successfull...
    And when I check the reason I saw that the XDNP81 is soldered very "dirty"... after 20 times of using and tests the Adapter is crap I asked for repair and they told me that it`s not possible to get only XDNP81, it`s only possible to get it in the complete set.
    I have VVDI2, VVDI Prog, Condor XC Mini Plus and many Adapters, with Licenses about 5000 Euro but this is the first time when I`m very disappointed from Xhorse.
  9. The Following User Says Thank You to Tabaluga For This Useful Post:
    Fallen (18th May, 2024)
  10. #8227
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Looks like you got bad quality adapters. On mine the soldering job is perfect.
    Also a smoke means a lot of current going somewhere. Something definitely got cooked.
  11. #8228
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by neilp1990 View Post
    Hello, I have gone to remove eeprom from fem module and it will not come off, won't read by clip neither I'm on step 2 of programming fem/bdc on vvdi2, it warns me not to exit what can I do as I'm unable to remove eeprom. Also what can I do if eeprom has failed?
    Thankyou
    I restored coding all fine, I just can't get eeprom off pcb never experienced anything so tough as one on a fem board from a f20.
    Its not an easy task to remove this eeprom. Only hot air gun and flux is not enough for that b1tch. Look for laquer removal chemicals and combone it with hot air. Repeat cleaning process multiple times, it will be easier. Need a lot of patience 🙂 I know its late answer but its tipo fot the future work
  12. #8229
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Read and write with the vvdiprog and adapters in circuit
  13. #8230
    Sep 2021
    I know is a vvdi2 topic, but some of you, have key tool plus... I used for fem, this yanhua clip ( see attach ) with key tool plus.. its more better then vvdi eeprom clip for fem...
  14. The Following 2 Users Say Thank You to Raould For This Useful Post:
    p1et (23rd May, 2024), scotlock (25th May, 2024)
  15. #8231
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Raould View Post
    This is what I use with vvdiprog
  16. #8232
    HeXeN's Avatar
    Mar 2015
    edit:nevermind
  17. #8233
    pepi's Avatar
    Is any body having problems with Prepare Proxy Remote - Database is lost . I try to reinstall but problem is still there.
  18. #8234
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by pepi View Post
    close vvdi2 inc close Quick lunch
    go to C:\Program Files (x86)\VVDI2\VVDI2\Transponder Programmer\DataBase
    delete that BIN file
    open vvdi2 - and software should download new one
  19. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    pepi (4th June, 2024), wuza (9th June, 2024)
  20. #8235
    pepi's Avatar
    I have already try that , it did not worked. If I go to Prepare super remote /regular remote everythink is OK,
    when I go to Prepare proximity remote it says DATABASE is LOST and the list is empty
