sniegavirs (8th September, 2019)
[QUOTE=auto techniek;3664686]I think there wil be no updates anymore
VVDI BMW (the blue box) is ready and wil wil available in the coming few days
[QUOTE=muskatas;] WT* why xhorse dont update VVDI2 with EGS ISN function........
What should the blue BMW box have advantages?
Now with the black box also CAS4 can be read via OBD. And the biggest mistakes are in the software itself.
For ECU / ISN, ECUs and CAS2 are missing. Thus no ISN calculation. CAS3 + always comes with errors that the type is not supported. What is already 2 years. The software always gets an update but there are not really many changes in the BMW range.
barho67 (10th September, 2019), ghostrider72 (10th September, 2019), jodge (9th September, 2019), sniegavirs (9th September, 2019)
Hello, is it possible to do akl in vw mqb models that dont use the 24c64 cluster? I know that vag helper can read immo data, is the problem we have is with the “sync file” to make a dealer key?
Cheers
i am trying to program new key to a toyota mark x smart system. my problem is i am getting error message "ERROR: 1 key detected. unable to make a key" and also i have a toyota camry smart systems which i want to change the key position to either number 2 or number 3 but vvdi2 only allows me to program key number 1 only. can this be rectified please
Today I did Audi S4 with RB4 cluster. I added key and now I have def error. How to fix this? I tried to write back eeprom but fail to write.
Sent from my SM-G970F using Tapatalk
iamfooser (12th September, 2019)
Check abs coding with vcds
If lost you need to restore it. With no abs backup will be tough.
Tools owned -
Why on Passat edc17 CS does not show up when try to read by obd?read success but no CS.
It should say ... successfully take off glove box and read CCM eep than we can give you cs......!!
