Page 414 of 552 FirstFirst ... 314364404409410411412413414415416417418419424464514 ... LastLast
Results 6,196 to 6,210 of 8278
  1. #6196
    Apr 2016
    uk
    Quote Originally Posted by sdnatlst View Post
    CORRECTION - customer now told me actually its 57 plate, Q7.
    So does that mean i can do AKL OBD as it would be a 128 EZS or not?
    Yes,all obd
    Sent from my MI MAX 3 using Tapatalk
  2. The Following User Says Thank You to comizelu For This Useful Post:
    sdnatlst (5th July, 2019)
  3. #6197
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What obd mcu 256 ?12 bytes cs akl? Dreamer
    Renault ECU tool / IO terminal / A.S.W
  4. #6198
    Apr 2016
    uk
    Quote Originally Posted by drugowaz View Post
    What clip your talking about. Need remove all steering rack,cut bolts, open elv read mcu in cirquit ant that program. 256mch bdm point on condensers super small ,not like 128mcu read easy.
    Q7 2010 will be 256 100%
    Probably he thought is eeprom...not MCU.
  5. #6199
    Apr 2016
    uk
    57 plate means late 2007 or early 2008.
  6. The Following User Says Thank You to comizelu For This Useful Post:
  7. #6200
    drugowaz's Avatar
    Mar 2015
    Lithuania
    We donk know what is plate 57
  8. The Following User Says Thank You to drugowaz For This Useful Post:
    immoneard (6th July, 2019)
  9. #6201
    sdnatlst's Avatar
    Aug 2011
    England
    Great thanks! yes 2007 car ,
    sorry i have never removed EZS so had no idea what MCU or EEPROM it had inside!
    now i know its OBD job, so i can tell customer i can do it
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
  10. #6202
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Don't say, until you have done it
  11. The Following User Says Thank You to drugowaz For This Useful Post:
    p1et (5th July, 2019)
  12. #6203
    Apr 2016
    uk
    You can call me if you have problems.
    Where is the car?
  13. #6204
    sdnatlst's Avatar
    Aug 2011
    England
    Quote Originally Posted by comizelu View Post
    Where is the car?
    Thanks please PM your number in case
    i am going to job Tuesday, as i dont have key in stock, but taken deposit for job so its for sure.
    Car is just north of London
    Tools owned -
  14. #6205
    Jul 2019
    You have to read ECU and get 6 byte CS and pin. Then go to AUDI Key menu , find A6/Q7 , enter manually CS and Pin, Prepare dealer key, then program it , Everything in same menu.
    If key buy form Dealer , then no need prepare dealer key, just program it after you you put 6 CS and Pin.
  15. The Following User Says Thank You to immoneard For This Useful Post:
    yugo45 (4th August, 2019)
  16. #6206
    Oct 2016
    France
    hi,how to change remote data filles in vvdi2?
  17. #6207
    Mar 2015
    UA
    Hey. Who can explain this to everyone? There is no English, only Chinese? Or maybe there are some settings to fix this?
  18. #6208
    Jun 2013
    Quote Originally Posted by MVVL View Post
    https://www.digital-kaos.co.uk/forum...atabase-change
  19. The Following User Says Thank You to Weasel3 For This Useful Post:
    MVVL (7th July, 2019)
  20. #6209
    khalilo_de's Avatar
    May 2010
    Quote Originally Posted by Maartinj View Post
    if kessy system have no fault, make a new key ... kessy key
    maybe old key is not kessy , no EU ...what ever
    "they always working before"...and stop randomly , nobody do nothing ...
    As i told you before guys, the problem is with vvdi2 learning keyless key system (color tft 2013 dash),
    The customer take the car to dealer they re-adapt for him the key with online and the keyless system is working now in both key the old ori and the new ine
    Regards
    Envoyé de mon SM-G973F en utilisant Tapatalk
  21. #6210
    Oct 2016
    Slovakia
    Hi , can VVDI2 transmit immodata from one BCM2 to another BCM2 (Audi 2010,2012) Thanks
