sorry i thought you are already using it, working
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
such a toy as a dragon xcan uhds, + key maker, does not hurt, but it's old
has anyone done VW Touareg 2017 - Add key with VVDI2? or BCM2 encrypted?
thanks for the help
hi PCF7943 – new , empty transponder chip for use in BMW E65, E60,
i have a q7 from 2013 want to make spare key for it (banana key). the vvdi can not read cs thru obd, so i have take out the ecu and read it on the bench i have now the cs (6byts) and pin from the ecu.
can i put now manuely the cs and make dealer key and add key ? or do need also to read J518 ? DIGITAL KAOs.jpg
No. This year you need 12byte. 6 not enought
Need full cs from elv
Renault ECU tool / IO terminal / A.S.W
Open elv. ,read dump. Make key into dump or learn obd precided data
You said spare key , so you have working key ?
If you have working key You did wrong at beginning , you do not need to read ECU if you have working key, so all this time you spend is for nothing .
Just read J518 ,use 256k option, save eeprom , then make a dealer key and program it , put 2 keys total .If you have key form Audi Dealer then no need to make dealer key.
