Page 385 of 548 FirstFirst ... 285335375380381382383384385386387388389390395435485 ... LastLast
Results 5,761 to 5,775 of 8219
  1. #5761
    Feb 2010
    Quote Originally Posted by hojo25 View Post
    BMW FEM edited with VVDi2 and it works very well. Disadvantage if you choose German language then you should also speak German on the right and not in Spanish or anything else.
    2 FEM ISN at VVDI 2 is identical to BMW Explorer !!!
    Is this a copy of VVDI 2 ???
    3 if VVDI2 here after why does it not then VVDi2 to state cas3 + correctly to read and write?
    A Chinesse of 100% Programmiert brings the finished the CAS3 + works. VVDI2 has several workers and does not do that.
    Autohex2 and BMW Explorer can do that for a long time.
    And VVDI2 can not do that which is ridiculous here.
    And it does not cost a lot !!!
    I don't understand you... Please can explain better?
    Enviado desde mi MI 9 mediante Tapatalk
  2. The Following User Says Thank You to hipolitogt For This Useful Post:
    p1et (18th March, 2019)
  3. #5762
    RG550's Avatar
    Oct 2017
    Any news for FIAT, ALFA... FCA vehicles?
  4. #5763
    Jan 2019
    Quote Originally Posted by cfgebel View Post
    Attachment 603848the update star 40% then stop
    Hallo
    1 Press find your interfase
    2 Press download
  5. The Following User Says Thank You to Contact For This Useful Post:
    cfgebel (19th March, 2019)
  6. #5764
    cfgebel's Avatar
    Feb 2009
    HASSI_BAHBAH
    Quote Originally Posted by Contact View Post
    Hallo
    2 Press download
    yes i try it but no luck
    Say will not happen to us except what Allah has decreed for us
    do not forget to say
  7. #5765
    May 2013
    Default BMW F10 - All keys Lost - ISN required
    So I have F10 5 Series Diesel with All Keys Lost.
    I prepared the FEM/BDC but need ISN.
    Tried to read ISN with VVDI2 and it says that it will read the RAM file and this file Xhorse would able to get ISN from it.
    I have the files herewith. Hope somebody can help with it.
    Thanks alot
  8. #5766
    Dec 2008
    Quote Originally Posted by obeids View Post
    Thanks alot
    F10 will be CAS module not FEM
    VIN number shows up as F30 !
    Also, RAM file is all 00's
    You need to read ECU on bench to get ISN
  9. #5767
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Thanks alot
    obeids it is F30 3 series!!! Are you sure you know what you are doing!??
  10. #5768
    Sep 2013
    Hello.
    I need unlock hitag pcf7935as from a8 2004. I have ori dump from Kessy.
    Any update in future for this in vvdi2??
  11. #5769
    Jan 2019
    Quote Originally Posted by adrian1914 View Post
    Hello.
    1 time programming chip can not unlock.
  12. #5770
    Sep 2013
    So then it’s no chance to renew a8 key?? I was try with new pcf7935as but it’s even not recognizing it.
  13. #5771
    Dec 2009
    There isn't any tool available that unlocks them.
    A8 needs precoded PCF7936 not PCF7935
  14. #5772
    Sep 2013
    Yes you right I write wrong, originally it’s PCF7943AT. Can be precoded?
  15. #5773
    Dec 2009
    Yes, Key learn -> 4th Immobilizer System VW/Skoda/Seat -> Touareg/Phaeton/A8/Cayenne/Bentley Immobilizer
    Key needs to be new and not locked. Used keys cannot be reused!
  16. #5774
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by exe123 View Post
    but this audi A8 is 2004 year.it is old kessy system and pcf7946 or standart chip 7936
    all a8 and toureag to 2008 it is old system
  17. #5775
    Dec 2009
    Quote Originally Posted by rola1971 View Post
    And? The menu I have pointed out is for the OLD kessy system from VDO/Conti with Hitag2 key...
