Page 485 of 548 FirstFirst ... 385435475480481482483484485486487488489490495535 ... LastLast
Results 7,261 to 7,275 of 8219
  1. #7261
    Aug 2009
    Quote Originally Posted by MVVL View Post
    Hey. On the new version, the program does not detect the device. Install back the old version everything is OK. Installing drivers, as in a help, does not help. What kind of problem? Or is it just me?
    update interface and will work!
  2. #7262
    Apr 2013
    nothing new with the update they haven't implemented anything long ago nothing new mqb
  3. The Following User Says Thank You to torero233 For This Useful Post:
    immoneard (31st May, 2020)
  4. #7263
    Dec 2016
    simply plug USB to laptop after install latest V6.7.5 firmware + software
  5. #7264
    Apr 2016
    how to prepare mqb dealer key in lost all keys situation? in mqb menu vvdi2 ask to switch ignition on with working key, nonsense
  6. #7265
    Apr 2016
    uk
    Quote Originally Posted by K1nd3r View Post
    Prepare dealer key with immo data
    Sent from my MI MAX 3 using Tapatalk
  7. #7266
    Apr 2016
    uk
    You need immo data and sync file
  8. The Following User Says Thank You to comizelu For This Useful Post:
    K1nd3r (30th May, 2020)
  9. #7267
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by TERMINATOR1000 View Post
    First upgrade firmware after that sw
    And everything ok
    Sent from my SM-J415F using Tapatalk
  10. #7268
    Jul 2019
    Quote Originally Posted by jokir View Post
    I have a 2012 BW Kessy cluster 7N0 920 870 E, H03, SW 0607 and I want to change in a color cluster 7N0 920 880 N, SW2030
    I copied the Immo Block with VVDI 2 into the new cluster, my problem is that when I transfer immo data to a new information panel and install it in the car, the dashboard does not turn on at all.When I press the tart button, the alarm lights do not come on at all and I cannot connect via PC
    Could someone help me with right configuration?"
    You need to write complete Immo block form Original cluster. So load original Immo block , then write .
  11. #7269
    Dec 2016
    HELLO
    Latest polo & ibiza ; MQB A0 ( 2018 + ) are supported ? Any advise ?
    Best regards
  12. #7270
    Feb 2014
    HELLO
    Best regards
    These only with ODIS with license.
  13. The Following User Says Thank You to autoTkey For This Useful Post:
    TERMINATOR1000 (4th June, 2020)
  14. #7271
    Dec 2016
    Quote Originally Posted by autoTkey View Post
    thanks but need OEM key or Made In China ?
  15. #7272
    Feb 2014
    I don't know - haven't used this tool. But I guess it doesn't matter what's the key since ODIS updates info in both car and online in VW servers...
  16. The Following User Says Thank You to autoTkey For This Useful Post:
  17. #7273
    Dec 2016
    yes of course , online tool !!!
  18. #7274
    ASCM's Avatar
    Oct 2018
    i think need oem key from dealer just
    For learning with odis,
    Odis not have access for preparing
    Aftermarket key
  19. The Following User Says Thank You to ASCM For This Useful Post:
    musti418 (4th June, 2020)
  20. #7275
    Feb 2014
    Isn't it possible to use VVDI2 to make dealer key and then add it with ODIS?
