Page 488 of 548 FirstFirst ... 388438478483484485486487488489490491492493498538 ... LastLast
Results 7,306 to 7,320 of 8219
  1. #7306
    Faraday's Avatar
    May 2012
    The dark side of the moon
    This ridicilus quene 11 wait 11min
  2. #7307
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    not too bad i was 56 other day
  3. The Following User Says Thank You to whiskeyman For This Useful Post:
    Faraday (25th June, 2020)
  4. #7308
    Oct 2018
    Northern Ireland
    I was 43 the other day and 18 on KD
  5. #7309
    Dec 2016
    for easy cars , better is add key , no queue !
  6. #7310
    Oct 2018
    Northern Ireland
    Very true but cloning handy for awkward or modified vehicles
  7. The Following User Says Thank You to Jimmy07 For This Useful Post:
    TERMINATOR1000 (26th June, 2020)
  8. #7311
    Romania
    Quote Originally Posted by immoneard View Post
    Anyone try Nec 24c64 with Sw 20xx ,AKL and add key ?
    This is still PQ dash , not MBQ.
    Not work this new version yet, I tried on new t6. But be careful this is aes key and no more remote learn in bcm
  9. The Following User Says Thank You to ghitab For This Useful Post:
    immoneard (27th June, 2020)
  10. #7312
    Sep 2016
    Skoda kodiaq 2019.
    VVDI2 + VAG helper can add smart key?
  11. #7313
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Jimmy07 View Post
    agree it could be a nightmare especially on VAG when the km is modded with cheap stuff
    Sir, are you classified as human? Negative, I am a meat popsicle
  12. The Following User Says Thank You to jodge For This Useful Post:
  13. #7314
    Default TOYOTA AVENSIS ID70 AKL ***SOLVED WITH TANGO***
    how to move transponder to position 2?
    immobox 89780-05030
    24c04 dump
  14. #7315
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by djollie View Post
    how to move transponder to position 2? immobox 89780-05030 24c04 dump
    everyone who want complain - you can asy use this link
    http://www.xhorse.uk/issue
  15. #7316
    Mar 2010
    Timisoara
    https://www.digital-kaos.co.uk/forum...=1#post3129043
    from the link above
    i have a tiguan with key less entry and go with 1 key
    elv vas busted added a second hand elv adapted online
    from where i read immo data?
    problem is that ecu is bad and cannot read anything from it
    Attached is kessy eep
    Thank you
  16. #7317
    Sep 2016
    In Device type,need to add "Xhorse VVDI2 Toyota 8A All key lost adapter" This is also a product Xhorse.
  17. #7318
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by lock66 View Post
    Toyota 8A can not wortk alone , so you can select VVDi2 because this is your main device
  18. The Following User Says Thank You to Maartinj For This Useful Post:
    lock66 (1st July, 2020)
  19. #7319
    rob h's Avatar
    May 2011
    msd812 BMW
    Tried reading isn with vvdi2,
    I can connect, when i press read isn, i get the message: can not get the unit name!
    is this common?
    I do not have another tool to read the isn.
  20. #7320
    damih's Avatar
    Jan 2010
    france
    Hello no one have tryed new option made a key via obd CAS4 in 2min ??
    thanks for any feedbach
