Fuse 5 and 15 but it disable also ABS. SCR stop working if you don' t have emulator then EDC lamp will ligtt on.
Thanks for your replay.I instal emulator but when I removed them the truck go in limp mode is on limp UDS and ABS and check.
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
What is model of car, what engine Cursor ? EuroStar have only Cursors motor at most, u write 160e18 for me looks for TECTOR motor, Maybe VIN i will try to look deply into problem and tell u solution perhaps.
Iveco Eurocargo 2006 year motor 3.9l 134 kW typ:F4AE3481A
Best regards
gitko (16th August, 2015)
