please use this file,should be ok for your car !
disconect differential pressure sender
Mike
Hello guys!! Here i have a hard one for the tuners. Can someone help me to remove the DPF from this dump? Its a Chevrolet Spin 1.3 edc17c59 0281019089 with a tc1767 mcu. Really hard to read. Full dump from original Ktag attached (thanks to a friend for the reading, chinese clon cant do this). The car has the next DTC: P2428 and P2453. Some guys just break the DPF instead of making a regeneration with original tool, and now we have to save the car. Will try and report results. Thanks in advance, Andrey.
Mike
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
charlytronic (9th May, 2019), inunxelex (29th March, 2024), shtyrya2 (18th August, 2015)
Thank you!!! Will try and report.
Hello, today we try the car and worked perfect without disconnecting the sensor. (First we disconnected the sensor, but appear a temperature dtc p2033, so i supose it was a wrong sensor... connected again worked perfect) Thank you for your help, great work!
Hello,how do you can read that ecu spin diesel 1.3? What cable use
[QUOTE=shtyrya2;2578384]Hello guys!! Here i have a hard one for the tuners. Can someone help me to remove the DPF from this dump? Its a Chevrolet Spin 1.3 edc17c59 0281019089 with a tc1767 mcu. Really hard to read. Full dump from original Ktag attached (thanks to a friend for the reading, chinese clon cant do this). The car has the next DTC: P2428 and P2453. Some guys just break the DPF instead of making a regeneration with original tool, and now we have to save the car. Will try and report results. Thanks in advance, Andrey.[/QUOT
How do you read the ecu
Your answer is in the first post - original Ktag.
ecutuners (10th December, 2015)
