Results 1 to 15 of 25
    Default missing channels
    Hi all
    I am from the west midlands area
    I have a few missing channels
    I have got 2 X Arnet A700C (Kryptview) boxes
    Box 1has got all channels
    Box 2 has got a few missing - sky sports 2 - sky premier are just a couple to mention
    I have downloaded the latest flash 12/07/2009 from this site and installed it onto box 2 but I still have the problem with the lost channels (by the way thanks for the updated version, the epg works great)
    I have factory reset and rescanned over 30 time?s to-day but I still fail to get the channels
    The odd thing is the other box 1 has 295 channels and Box 2 is only finding 270
    I have tried a factory reset and rescan on box 2 where box 1 is normally used but still the missing channels will not reveal themselves
    If I put box 1 in the position that I use box 2, I can still assess all the channels?
    I have not tried to put the new flash version onto box 1 yet because I don?t want to be in the same predicament as I am with box 2
    Sorry it so long winded, I have tried to give you all the facts as I have them
    Many thanks and hopefully someone can help me with this.
    Nov 2008
    N*L EIRE
    Post
    [QUOTE=guinness;244494]Hi all
    A 750 model has a power-scan function in menu
    When enabled put box in standby for 1 hour, it will manually scan all TP's.
    If this function is not on 700 model you have some work to do.
    On box 1 go to TP edit, scroll down thru TP list, note all TP values.
    On box 2 go to TP edit, any TP values not present, you can add them
    manually, just go to bottom of list,hi-lite empty line & add TP value.
    Then try several scans,use different legacy options each time.
    If this fails re-flash with 13/03/09 and re-scan
    thanks for reply
    i have been in standby since i posted - so i will check if it has updated as it does have this function.
    will let you know the progress
    Apr 2009
    I have the same problem (but I have an a750), missing BBC 3 & 4 and a few others that I'm not too bothered about, but I really would like to get the BBC's back.
    Any suggestions?
    I tried reflashing with 13032009 firmware but I just loose more channels.
    I am in Ireland - south, on MMDS.
    Thanks.
    Nov 2008
    N*L EIRE
    Post
    [QUOTE=caolan;244731]Hi,
    Any suggestions?
    On NTL mmds use latest fix july 2009 it will improve your remote
    For missing chls. turn on power-scan mode in menu, put box in
    standby for 1 hour or even overnight. Box will then manually scan.
    If chls. are not found you may be missing 1 freq on TP list.
    TP nos. N*L MMDS are; 250MHz; 266; 282; 298; 314; 330; 346;
    362; 378
    Check these nos. in TP EDIT, manually add any that are absent
    RE-scan using different legacy options if necessary
    Apr 2009
    thanks have it on power scan now.
    hopefully that sorts it out. All the TPs are correct.
    Thanks again.
    Hi again
    I have left on standby over 4 hrs - still missing channels - I have been told that my box is self scanning - I cannot find any method for editing tp's - only adding, this will only start from scratch and goes from (tp 1 already exists all the way to 42 - takes about 1hr each time) then re scans my channels and says no new channels found. – Exit to continue.
    I have Been on this for 3 weeks now - I have-not posted because I have been reading other threads and trying to solve myself with various bits of snippets I have read via other users with same problems but in different areas and different boxes - this box seems to be reasonably trouble free in general ?
    Any help would be appreciated – thanks for the help and suggestions so far
    Nov 2008
    N*L EIRE
    Post
    [QUOTE=guinness;244786]Hi again
    In menu find TP edit, then press OK, select correct provider.
    Scroll right to hi-lite first TP value, scroll down thru TP list.
    When last TP is hi-lited scroll down to next line which will be empty.
    Press OK to ILLUMINATE empty line & add missing TP value that you have
    found on BOX 1 TP list. Wish you luck
    [quote=EAMO 2;244810]
    Quote Originally Posted by guinness View Post
    Thanks for the info - I must say that I did not know about this place, so I have learned something new.
    Unfortunately for me I have got more tp's in box 2 than I have got in box 1
    In box 1 = 38 = more channels
    In box 2 = 42 = less channels
    I have gone through every tp in both boxes and box 2 has every tp the same as box 1 + 4 more
    The plot thickens
    thanks again for your tips - its getting late so i am going to put it into standby for to-night and see if there is anymore ideas in the morning
    once again thanks to all for reading and helping with my problem
    till the morning
    Morning all
    I left the box on standby over night (scan mode).
    I have noticed a couple of channels that said (no signal or scrambled) are now working, but sky sports 2 or premier are still not there.
    any ideas welcomed
    Nov 2008
    N*L EIRE
    Post
    [QUOTE=guinness;244952]Morning all
    You're getting there. Lets see if we can finish it off.
    On box 1 go to each chl. that is missing on box 2
    On each chl. hit OK--INFO, this will show details of channel
    Note the FREQ. (tp) value on each channel , they may be on same TP.
    Swop box 2 to box 1 location. You may have better signal at box position 1.
    Make sure problem TP values are on TP list on box 2. Do an auto-scan.
    Do several scans using different legacy options each time
    Check after each scan for required chls.
    If this fails go to Manual-SCAN, enter required TP value & manual scan.
    Repeat this for each problem TP value
    Your last resort (if necessary) is to put box 2 in box 1 location overnight
    & put in stand-by.
  13. #13
    [quote=EAMO 2;244971]
    Morning all
    hey EAMO 2
    some great idears there - i have to go out now but i will be back about 6pm to put your tips into practice
    i will keep you posted
    one thing about this is you can always learn something new.
    thanks very much
  14. #14
    Hi all
    Sorry for the late response but I had to go and work away for a few days - I have done what you suggested (EAMO 2) with the manual search on the missing channels but it keep saying no new channels found.
    I am going to change over the box positions to-night and see if your last suggestion works - keep you posted
    Many thanks
  15. #15
    Apr 2008
    you can download channel data from one box and put it on the other and see if that helps. i think you have to connect box to tv and pc and in menu there is a data download option
