Did you scanned car before opening ecu? Check ecu pins also
Egr off and one problem if someone have explanation.
After I unlock eeprom 25640 I get one problem... i tried with ori eeprom file, but the same.
If I want to start the car, car does not start first time but in second attempt... This is everytime when I try... I also noticed that engine rpm are higher: 1150-1200...
This are dtc read with VCDS:
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 GL HW: 03L 906 023 A
Component and/or Version: 1,6l R4 CR td H23 5810
Software Coding: 00114034032401080000
Work Shop Code: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM16TDI02103L906023GL 001006 (VW46)
ROD: EV_ECM16TDI02103L906023GL.rod
VCID: 76E3E5D1C9D63F8E7C-8022
2 Faults Found:
6110 - Crankshaft Position Sensor (G28)
P0335 00 [167] - Malfunction
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 188059 km
Date: 2063.14.08
Time: 00:53:11
10449 - Starter Will Not Turn
P3054 00 [167] - Jammed or Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188059 km
Date: 2063.14.08
Time: 00:53:11
Readiness: 1010 0000
Can someone remove the egr from file. And if someone know what should be problem?
pcbox (17th August, 2015)
This can not be problem with ecu...
What tools did you used for unlocking?
There was no fault on ecu except egr... But I done 6 this ecus without problem and i open it realy carefuly
Minipro eeprom programmer and PcrUnlocker program.
Here is the ori and ulocked file
Did you used minipro and pcrunlocker for all 6 ecus? Did you take car for a test? Is all runing good?
Yes. I take car for a test and everything seems ok. Except rpm increased and esp light (In abs chanell I get error (Check engine dtcs),.. I did not touch the flash... I should do egr off, but now I have to solve this problem first. Is there any way of diasabling start stop system in flash and removing this dtcs?
Thank you
someone will disable dtc about G28 for sure,but in the future if G28 will dead or it have other kind of trouble from wiring ...can you tell as how will start that engine ?
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
I always check engine rpm in parametres... I just wanna try,..
with cars from customers you cant try some kind of "magic",better are to check that plug/wiring from ecu maybe it have broken one pin when you have replug ecu in car
or that G28 are broken or damage by flywheel
Full WinOLS user
Mihai can have right, better if you check ecu pins and clean connectors
Epprom can't do that's problem, really ! Can forget about it.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
I know that is right... I will check wires and conectors tomorow... But I was realy desperated and you know, I just wanna fix it in easy (not right) way...
I do not know. I noticed this more times... This is read by genuine vcds cable, not clone.
Tuesday,18,August,2015,09:50:02:04354
VCDS Version: Release 15.7.0 Running on Windows 7 x86
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Control Module Part Number: 3C0 614 109 AK HW: 3C0 614 109 AK
Component and/or Version: J104 C4 440 V2 0027
Software Coding: 0033263
Work Shop Code: WSC 05311 000 00000
VCID: 67DDB895567CD606F7-8032
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 171
Mileage: 188074 km
Time Indication: 0
Date: 2063.14.08
Time: 14:35:51
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 163
Hex Value: 0x0000
I also have this error in abs unit... If start the car, eso light is on, and I can only remove light for one second if I erase fault.
