Results 1 to 9 of 9
    DK Veteran 70max's Avatar
    May 2012
    Default Please help delete DTC Peugeot 1600 HP110 ECU 16C34
    Hello Friend,
    please delete me from the DTC's file?
    P0405
    P1728
    P2033
    Look at the attached image
    ECU Bosch is 16c34 fap eliminated by bit
    Peugeot 307 1600 HP110 ECU 16C34
    Thanks for your help
    This is dtc off.Pass pm
  3. The Following User Says Thank You to nikka For This Useful Post:
    70max (19th August, 2015)
    May 2012
    I will write files next week
    I'll give you confirmation if everything is ok.
    Many thanks
    Best regards
    May 2012
    Hello Nikka,
    The file that you made me work well.
    But now I have another DTC can you help me to get rid of?
    DTC P0238
    View on Screen
    There mate.Password is same.
  7. The Following User Says Thank You to nikka For This Useful Post:
    70max (25th August, 2015)
  8. #6
    May 2012
    Thanks friend,
    Tomorrow I write and let you know
    if it's all right.
    Many thanks
  9. #7
    mihaiservice's Avatar
    http://www.quick-tuning.com
    After all this dtc erased from flash .....that car will be in good condition ? no limp mode after first corner ?
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  10. #8
    May 2012
    Quote Originally Posted by nikka View Post
    thanks Nikka
    I did not write the file DTC-0238
    I solved the problem by leaving press turbo stock
    Thank you very much for your help.
    Best regards
  11. #9
    Jun 2012
    did u manage to clear p1728 ?? and was it permanant dtc ?
