Results 1 to 12 of 12
    Default MB airbag crash data
    hello,
    Need clear airbag dump. Can anyone help me?
    Mercedes Benz C180 MY2005
    0 285 001 813
    Q4
    bosch
    memory cr16mct9
    adam28's Avatar
    May 2009
    UK Essex
    Here you go
    Jun 2009
    Quote Originally Posted by aaruncee View Post
    hello,
    0 285 001 813
    Q4
    bosch
    memory cr16mct9
    here you go:
    Quote Originally Posted by sixpack View Post
    here you go:
    i'll test tomorrow. thanks friends
    Jun 2009
    did you reconfigure the module, and read, deleted DTC's?
    adam28's Avatar
    May 2009
    UK Essex
    Good point.
    after DTC's reset car dash display show one fault:
    Restraint System Malfunction: Drive to Workshop - SRS
    adam28's Avatar
    May 2009
    UK Essex
    Did you replace all the blown airbags and pretensioners?
    If so check and WD40 all the Airbag connections especially the pretensioners.This has worked for me on many occasions.
    You really need to read the DTC with diagnostic machine to narrow it down abit
    Jun 2009
    I see that you ask for a solution on a other forum to.
    my best guess is that you do something wrong, i suggest that you follow the advice from Adam28 in the post above
    Hello, i found the problem: passenger seat sensor. How can I solve this problem? I have heard that there are emulators for this sensor? Can anyone suggest any solution without the purchase of a new. thanks
    Jun 2009
    why emulate, do you want to play with you live or that of others, replace it with on from scrap yard
    adam28's Avatar
    May 2009
    UK Essex
    Sixpack is right mate,airbags are there for a reason. You can emulate with the correct resistance, so the module thinks the airbag is there and is in working order, but this is a cowboy way of doing it. That airbag could save someones life.
