taxo1965 (12th April, 2017)
hello all DK members,
I need a bit of help clearing this file . i manage to read it without breaking the whole unit by pads with xprog M .
read and veryfy correct - mask is 3M25J - MC9S12XEQ384_EEE
EEprom_Insignia_MC9S12XEQ384_EEE.ORI.rar
Thanks in advantage
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Try it, report it......
bursuc (20th August, 2015)
Thank you - i will test it and report back - Regards
Still 3 fault codes and i am unable to erase them:
B0012-0E - DRIVER AIRBAG SQUIB - NCIRCUIT
B0015-05 - DRIVER PRETENSIONER CIRCUIT HIGH RESISTANCE
B001A-OD -DRIVER SEAT BELT PRETENSIONER DEPLOYMENT LOOP 2 - HIGH RESISTANCE
Nobody has any solution for this ? thanks
Can you produce new DTC-s ? For example: disconnect driver airbag and check will you get new DTC?
i does not register any new code when i unplug any of the airbag - By the way all airbag squib's have been replaced already . it could be only from eeprom . regards and hopfully somebody can help me with this
Did you try connecting a 2.4 ohm resistor on seat belt or seat belt stalk's plug? To see if you can clear those faults.
Besides steering airbag fault could be because of clock spring (some call it slip ring). You might wanna have a look on these parts.
bursuc (26th August, 2015)
Xprog it is saying is emulated 4 kb but 2 kb shoud be fine aswell as far as i do some searching on some russian forums.... i will try to put resistors on those 3 fault codes and check after.
I come back with result. Thank you
Sent from my SM-N910F using Tapatalk
please can you clean mine mc9s12xeg384
