Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 78
  1. #16
    Top Poster mexjack's Avatar
    Philippines
    Hi:
    Could you help me to repair my dumps please?
    Thank you
    BR
  2. #17
    Nov 2015
    Ciao
    io sono nuovo del forum
    mi potete aiutare
    ho bisogno del file di Audi A3, 8P0920932N, flash e EEPROM grazie
  3. #18
    Aug 2015
    Quote Originally Posted by autotech82 View Post
    Ciao
    mi potete aiutare
    ?? Maybe in english someone can help you m8
  4. #19
    publiperro's Avatar
    Apr 2016
    Espaņa
    Default help
    I have error 014 eproom picture Audi A3 8P 8P0920931E, read via vag-com, the car does not want to boot, I could read the flash memory CDC3217g and the eprom 24lc32 with xprog 5.70 and the car will not start, I am without car for this problem I could Help, thank you in advance.
  5. #20
    publiperro's Avatar
    Apr 2016
    Espaņa
    please help.
  6. #21
    Mar 2017
    Dash comes top me dead after mileage correction by fvdi clone
    Can someone repair flash micronas?
    Tnx
  7. #22
    Mar 2017
    Thanks a lot, everyone!
  8. #23
    DSAuto's Avatar
    Cape Town , South Africa
    Hi Guys,
    I need someone to help me fix the dumps from A3 Micronas CDC3217G DASH.
    The part number is: 8P0920931B
    I have in the immo internal ROM error and in the DASH control module error.
    Thanks in advance
    Bets Regards
  9. #24
    May 2015
    argentina
    Default How to connect xprog
    : Mad-nueva:
    I'm lost with the diagram.
    Will you have a picture of the connection?
  10. #25
    DK Veteran stevan's Avatar
    Bosnia
    Hello to all,friend kill A3 2011 with Carprog,I have make dash alive with good flash but Immo active as Immo block is in MCU.
    Can anyone repair damaged flash.
    A3 8P0920932N VDO H02 sw0150
  11. #26
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    try my file friend.
    bR
    keep your friends close and your enemies closer
    Golden Section
    The Real ART
  12. #27
    Bosnia
    Tanks friend,i have try several possiblle solutions similar like your,
    I,m suspect that first 4 bytes are erased 00 00 00 00.
    But i cant found anywhere similar dump to compare,all dumps are totaly different from my.
  13. #28
    Oct 2008
    Eu.Gr
    i have not see any micronas with first line corrupted (until now)
    bR
    Golden Section
    The Real ART
  14. #29
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    What tool do you use to read Micronas?
    Is a corrupt dump.
  15. #30
    Bosnia
    Xprog,verify was ok.
    But i also was think that all dumnp was moved 4 bytes foward.
    If you see address 24 to 27 for locked state need to be aa55 aa55 but in my dump is from 28 address.
