Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
  1. #16
    Oct 2011
    Are you ready to believe?
  2. The Following 19 Users Say Thank You to vlad67 For This Useful Post:
    bursuc (1st June, 2016), dziongas (16th May, 2017), eka39 (1st November, 2017), evisdaci (18th June, 2018), ggpanos (30th September, 2019), hmagga (28th October, 2022), k.marcin (23rd February, 2019), m3touk85 (11th October, 2017), mahmoudbm (6th October, 2017), mahmoudfs (12th March, 2019), markiyan (13th July, 2016), mexanico1971 (13th March, 2019), raskolnikov1975 (28th June, 2017), rex89 (4th February, 2020), skens (21st December, 2023), suli25an (7th March, 2019), tunceroto (30th August, 2017), whim (8th November, 2018), Zmann (29th May, 2016)
  3. #17
    Nov 2010
    hi
    what is programmer read batter this chip (ST10F280-B3) ?
    thank you...
  4. #18
    Jul 2018
    my friends can read it with fgtech galletto 4 ?
  5. #19
    Jul 2018
    Quote Originally Posted by vlad67 View Post
    HI
    osc
    rdx
    What is that ؟؟
    Where to connect to xporg ???
  6. #20
    mapexo's Avatar
    Mar 2017
    Germany
    diagram test and not good sir...
  7. #21
    DK Veteran deluss's Avatar
    Jun 2011
    Did someone read this gearbox ecu by xprog ??
  8. #22
    Apr 2012
    Thanx Vlad67
    nice work!
    it's a pity some of us do not want to use their brains...
    b.rgds
  9. #23
    mapexo's Avatar
    Mar 2017
    Germany
    sorry sir, where are we wrong ?! I followed the pinout above
  10. #24
    Jun 2011
    So did it work ?
  11. #25
    mapexo's Avatar
    Mar 2017
    Germany
    Quote Originally Posted by piorad69 View Post
    Thanx Vlad67
    nice work!
    b.rgds
    sorry I followed the pin of the photo and connected on xprog! I also fed ecu externally! work failure!
  12. #26
    Quote Originally Posted by mapexo View Post
    Never work on this ECU but it should work. Have tested Xprog RX/TX mode on other ECU's and working fine.
  13. The Following User Says Thank You to Zmann For This Useful Post:
    drewdom (29th September, 2019)
  14. #27
    mapexo's Avatar
    Mar 2017
    Germany
    Xprog 5.51 and 5.55 tested ecu question and not work
  15. #28
    I would test...
    - if the ECU has Kline, try Kline mode with some other tool
    - lift/remove suspected component surrounding RST and RXD pads that may cause overload and try
  16. #29
    mapexo's Avatar
    Mar 2017
    Germany
    Can ECU, not have Logic Kline
  17. #30
    There are many simple Kline ICs if want to go!
