suli25an (7th March, 2019)
I need a bit of help on this gearbox ecu - on Peugeot 508 - 2012
I need to read software inside ST10F280 to transfer the data to an old ecu gearbox
Original somebody change the clutch and forgot to connect engine Ground cable - after that the gearbox ecu is not communicating anymore
I have another ECU from a Citroen C4 same gearbox ecu but older software version
ORIGINAL IS : CFC310P.01
SECOND IS : CFC300
Difference between them is most likely software - I have tried to program the CFC300 on the car but i am unable to start the engine when diagnostic is asking because i have fault code in engine ecu related to Incorrect signal received from Gearbox
IF somebody read one before i would appreciate a bit of help.
Thanks in advantage
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
have u tried to read the stf10. and swap info?
bursuc (21st August, 2015)
Thats i'm trying to do . i check the board - check components - not any component burn. It could be something related to the processor - but i am trying to fiind the pins to read the processor on this board.-
nobody has any clue ?
If none can tell the boot pin pad exactly, that could be guessed.
check xprog help files for connection directly
I got piasini fg tech and xprog. Wich one should work better ?
Sent from my SM-N910F using Tapatalk
i woudl use Xprog! sice the others wont read, unless via OBD etc..but this not a engien ecu is gearbox
anybody knows any other way to read this MCU ? i need the data inside of this ecu because somebody forgot to put the ground cable to the engine and now i dont have communication at all ...
any Help please ??
Hello
Did you solved this problem ?
Hello. I solved the problem. My problem was engine Ecu Siemens sid 807 evo wich didnt transmit can bus data to gearbox ecu. I will open the ecu now to have a look what may broke inside.
I fit the old gearbox ecu and new engine ecu - program the gearbox again and that is it
Thank all until now
elitricista (10th February, 2024)
Hello
I have exactly the same problem as you. Can you say something more, what the programmer did you use and can you upload soft for new ecu gearbox.
Thank you very much for your suggestions
Read carefully,he didn't read tcu ,the problem was in engine ecu ,old tcu was OK
bursuc (1st October, 2015)
I have the same problem, you need to transfer data to another processor control unit, how to read st10f280?
Very easy with xprog
some pins where to connect?
