Page 19 of 26 FirstFirst ... 91415161718192021222324 ... LastLast
Results 271 to 285 of 386
  1. #271
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    it works ME7.5 512Kb?
    possible to do?
    Don't forget hit thank button if i helped.
  2. #272
    Dec 2019
    Hi! i would like pop and bang my car.
    ME7.6.2
  3. #273
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by peke1123 View Post
    ME7.6.2
    here you go test and report
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  4. The Following User Says Thank You to chrisimerk For This Useful Post:
    peke1123 (19th February, 2020)
  5. #274
    pioneer427's Avatar
    Feb 2017
    Belarus
    Can someone add pops and bangs launch control. Big thanks
  6. #275
    Jan 2020
    Hello everyone, thanks for your help with launch control, i never got it to work no matter how hard i tried but never mind. Can someone make mi hard cut rev limitter and pops and bangs on my car.I would be very thankful for that. https://files.fm/u/tacqhk97 this is my current map. Thanks
  7. #276
    Dec 2019
    Dont Working :/
  8. #277
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by taxonovich View Post
    here you go pops and bangs and lc test and report also hope you have a built turbo as the standard one wont last long at all if your constantly doing it
    pass in pm
    (DEMON DEVELOPMENT)
  9. #278
    Aug 2018
    Hello, could someone please add launch control to this map? I have zero idea how to do in on me7.5. Thanks.
  10. #279
    Apr 2017
    Croatia
    Quote Originally Posted by vitaliyl View Post
    possible to do?
    Done with script, test but be careful, did some reading, there can be damaged coils with 512kb files. Chk ok
  11. #280
    Jan 2020
    Quote Originally Posted by chrisimerk View Post
    pass in pm
    i tested this file and nothing happens. but i have different problem now. I swaped k03s with k04 and i have 318cc injectors with 4 bar regulator and i cant get turbo map to be smooth while acceleration. It bilds u boost and then goes intro limp mode because too much pressure and it jerks while acceleration. thanks for your time
  12. #281
    chrisimerk's Avatar
    Dec 2018
    England
    thats strange the pops and bangs deffo should work as i have tested this solution on numerous cars and yeah you need to get it tuned to match the bigger injectors put your ori injectors back in and see if that problem persists also might start to pop and bang with your ori injectors back in as what happens is with your bigger injectors it basically starts dumping fuel in as its not controlled i had the same problem with my vrs after i put 630cc injectors in plenty of time and plenty of logging to get it right
    good luck
    (DEMON DEVELOPMENT)
  13. #282
    Aug 2018
    send me test, i have 1.8t BFB i will send video aswell can u add me pop and bang aswell, thanks
  14. #283
    Oct 2018
    Quote Originally Posted by share112 View Post
    and search in next thread....
    why you order in email and if done work you didnt pay?
  15. #284
    Aug 2018
    you got paid bud.
  16. #285
    Jan 2020
    good luck
    318cc are stock injectors, i only swaped k04 turbo. I found out problem, my intake hose was colapsing, i made it form metal and everything is ok but turbo pressure is only 1 bar while acceleration, i think it can be higher with this turbo. Would you help me and make me map so that i could get maximum out of this engine and turbo
