Results 1 to 14 of 14
    Aug 2015
    S. Korea
    Default Need Virgin Dump for W221 s350
    Hello
    Can anyone make me a virgin file for me9.7 W221 S350 0261209070
    Thank You
    Jakarta, Indonesia
    You should try to find a solution., many posting virgin ecu software in this forum.
    do not only receive assistance. If you want to help after can not solve the problem,we can help you,
    I do not agree, you just come with easy to grab something, you should try before asking for help.
    Aug 2015
    S. Korea
    I have tried almost everything with this car. I have tried few software's including mb renew v1.7 and almost 5 virgin dump from tuners. Nothing worked out for me.
    Jakarta, Indonesia
    Mb renew must work for this ecu but u need scn coding and manual coding for last step. What your problem? Ori ecu burn?
    Aug 2015
    S. Korea
    Yes original ecu was burned and bought a used ecu. I did a scn coding and didn't do manual coding at last. But after scn coding sucess i can't get connect to drive authorization fron das.
    What is the process of manual coding? SCN won't do all the job?
    Jakarta, Indonesia
    About part number ecu ? Same as original?
    Jakarta, Indonesia
    Make sure your ecu have 2 prosesor. Check in epc part number can use in your car.
    Aug 2015
    S. Korea
    Yes The bosch number and MB part number's are exact same.
    May 2015
    Write this EEPROM and do online SCN coding.
    or desolder original EEprom ( 95080 ) from burnt ECU and read and program to new used you must read it even if ecu is burnt
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by pitzone View Post
    Hello
    Thank You
    http://www.digital-kaos.co.uk/forums...oduce-Yourself
    Introduce yourself. . So we can help
    _______________ D3-oToprog _________________
    ig : vanos_batam
    Aug 2015
    S. Korea
    Thank You i will try tonight.
  13. #13
    Heaven or Hell
    it must renew flash
  14. #14
    alclot's Avatar
    Melee Island
    Hi man. Did you find solution there?
    Thanks a lot
