Also when i convert to ext 4 will i lose anything im new to this and not got a clue when ive got to the end of what you have told me to do its asking are you sure you want to convert file system
The H1 has a cable and satellite tuner, so all you need to do is connect your satellite cable, config the tuner and autobouquetmaker scan; (I take it for granted that you have Autobouquetsmaker plugin installed?)
1. Menu-setup-service searching-config tuner and Setup Tuner A - Config mode scroll to 'advanced' , Satellite scroll to '28'2e Astra' ,LNB scroll to 'LNB 1' leave all other options default, Press Ok (I think tuner A is the satellite tuner, it will be the one diasabled/not configured)
2. Follow the Autobouquetsmaker part of my guide but don't change any settings for VM
3. The next bit is against forum rules to discuss, but more importantly I don't know the answer so you will have to google search the answer, your decryption 'magic' will be for cable I don't know if it will work for sat.
If the person who setup your box didn't use Autobouquetmaker to scan for your channels, then you need a guide for whichever way he setup your channels.
You will only lose everything on the USB storage drive, so any movies, picons or EPG data will be lost. But If you did the first part of my reply ie Initialised the drive then you have already deleted everything?
I've been looking everywhere to find out how to stop the OTA updates updating to 0.8.1, thanks for this!!!
what does the 4. Menu-system-EPG-Crossepg-configure and ?Download on tune? to ?Yes? feature do??
martin035 (13th November, 2015)
boobishabang (13th November, 2015)
would it not stop this if all the radio channels
were deleted with the DCC panel
Please Read Carefully!
No Sky UK NDS Videoguard Hacking Discussions.
Viewing Pay TV without a valid subscription is illegal
the files available are kept for experimental & educational purpose only
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
