Results 1 to 10 of 10
    rm23's Avatar
    UK
    Default Citroen Relay 2010 remote not working after programming why?
    I have bought remote of 3dgroup remote number is Fir6c made by Istanbul Anathar from ieakeystore.com, I have read bsi eeprom with Avdi precoded key with file then coded by obd2. Car starts but no remote? Can someone tell why? did someone used this type of key on these cars and remote was ok? If you check remote on tester remote is fine. Central locking working fine when you use buttons inside the car or lock car manualy. Thank You for any advice !
    Atex31's Avatar
    Feb 2011
    UK
    Not had any issues with those keys apart from the price.
    Never tried to make a Fiat remote key with AVDI though.
    uk
    if this is a id48 type key then You need to program the remote with another tool
    HTH Adam
    on a side note does the key fit into the door lock with the blade they supplied
    rm23's Avatar
    UK
    My is id46 type, bsi number is 1364523080. Yes my key works ok on the door lock and in ignition.
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Simple -
    AVDI doesn't support remotes. You need TMPro2 or ZedFull.
    I am a FUD
  6. The Following User Says Thank You to obdsystems For This Useful Post:
    rm23 (26th August, 2015)
    autochei's Avatar
    Mar 2013
    romania
    and corect remote it s magnetti marelli like this http://www.autoremotecontrols.com/au...id=&Sr=&Gr=&St=
    Atex31's Avatar
    Feb 2011
    UK
    Quote Originally Posted by autochei View Post
    The remote part No he used was the correct Marelli type.
    Feb 2011
    H.............
  10. The Following User Says Thank You to workdamnyou For This Useful Post:
    obdsystems (27th August, 2015)
  11. #9
    rm23's Avatar
    UK
    job done today with tmpro2 and module 112 and avdi to read bsi via obd2, remote operate now !!
  12. #10
    autochei's Avatar
    Mar 2013
    romania
    Quote Originally Posted by rm23 View Post
    can u put ur dump here?
