Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Nov 2008
    Default pairing cd30 with dysplay
    i have astra g with a new display
    please help me to pair
    Feb 2010
    WALES
    Quote Originally Posted by vladgsm1 View Post
    Use dump from old display..
    wbr
    (Pin for radio is 9643)
  3. The Following User Says Thank You to shooting For This Useful Post:
    vladgsm1 (28th August, 2015)
    clydey's Avatar
    Feb 2013
    london kent
    cd30 code 9643
    display code 5069
    not sure regarding pairing cheers
    It's here somewhere ( a blind man looking for a black cat in a dark room that is not there)
  5. The Following User Says Thank You to clydey For This Useful Post:
  6. #4
    Feb 2010
    WALES
    My advise maybe mean nothing here but use original dump and no need to pair dump...
    wbr
  7. #5
    Nov 2008
    i not have original dump
  8. #6
    clydey's Avatar
    Feb 2013
    london kent
    here is your bin unregistered code 0000 cheers
  9. The Following User Says Thank You to clydey For This Useful Post:
  10. #7
    Feb 2010
    WALES
    Then you need OPCOM to enter 9643 into the new display..
    I assume your radio is original to the car.., if so at NO point change it's dump or you will not get anything to work 1000%
    wbr
  11. #8
    clydey's Avatar
    Feb 2013
    london kent
    even better I have been told is the tech 2 for this job cheers
  12. #9
    Nov 2008
    its ok now
    but i have "beep" in speakers at 10 second
  13. #10
    Feb 2010
    WALES
    its ok now
    What did you do to get this?
    Did you change the radio dump?
    wbr
    (BEEP means it is not yet solved)
  14. #11
    Nov 2008
    yes
    after i change radio dump with unregister dump
  15. #12
    Feb 2010
    WALES
    yes
    Then you now have a big problem and I can no longer help you... See my advise in post 7
    wbr
  16. #13
    clydey's Avatar
    Feb 2013
    london kent
    you now have two choices
    get a manually prepaired set of dumps (there is a pair but the owner wishes not to share- there may be others)
    get someone with tech2 (we already know that opcom has its limits)
    to pair the dumps
    or wait for a reply from someone who can help cheers
  17. The Following User Says Thank You to clydey For This Useful Post:
  18. #14
    Feb 2010
    WALES
    What Limits? Genuine OPCOM is the correct tool for OPEL cars..
    (Fake Chinese OPCOM's aren't really OPCOM's)
    wbr
  19. #15
    clydey's Avatar
    Feb 2013
    london kent
    ok another experienced poster said bloody nightmare buddy
    and I cannot disclose what was said in private pm with him
    I do not know if you or the other poster in the last scenario was using the ?38 fleabay shineese
    version but I do know that it was sorted by a manually prepaired set of dumps
    but what I was told in pm was get yourself the tech2 by same poster
    cheers
