Results 1 to 7 of 7
    DK Veteran KenshinPT's Avatar
    PT
    Default Is it possible to deploy the airbags using the OBD2 port?
    I built a hardware based on an Arduino to communicate with the CAN bus.
    I want to read some data and then print it on the multi function display of my car.
    The problem with this project is that uses lots of trial and error by sniffing the bus.
    So, if I send the wrong / right command can I deploy the airbargs?
    Thanks,
    Vasco
    Did it help? Push Thanks below
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    No if you unplug the srs module
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    I think:
    Yes if you don't unplug the SRS module.
    May be a safer answer.
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Personally I think that random numbers down the CAN has a lot more potential for big bucks damage than just the air bags.
    Senior Member amlgarA's Avatar
    Aug 2015
    yes you can DEPLY AIRBAG, if your scanner has TEST COMPONENTS IN airbag system don't do it, USSUALLY found in VW, AUDI, PORSCHE,and some more brands, has this function, some scantool warning you before test airbag components with scan tool, you can command the airbag module to release voltage to airbag will fire it.. CAREFULL , OR YOU CAN DEPLOY AIRBAG ALSO IF YOUR SCAN TOOL HAS A SHORT ALSO..
    Remember all my post, comments and files are for educational purposes only , you take your own risk using my post and files
    PT
    Thanks! I'll stop this project then. Disabling the SRS makes no sense because I want to print the data in real time. And I don't want to drive with the SRS disconnected.
    Sent from my LT30p using Tapatalk
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    If you want to use an Arduino for something useful stick it behind the OBD so you can't see it then take it to Toyota or wherever and have it capture all the data and the direction it went. If you could do that with every car you could make one hell of a tool. You could collect all the information to do everything the manufacturers tool does.
