Results 1 to 7 of 7
    Default Is possible turn off MAF on Vivaro?
    Can someone help me, is possible turn off MAF on Opel Vivaro 1.9cdti, edc15c3?
    Car have 2 dtc
    p0100 MAF sensor circuit high imput - intermitten
    p0113 Intake air temp. circuit high imput - permanent
    when i check live data whit autocom MAF sho 0kg/h whit plugged and whit unplugged MAF too ...
    Sounds like a wiring problem to me, because the intake air temp. sensor is probably build into the MAF.
    think too ... is it possible turn off mar on this car, or change limiters for maf to maximum?
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    dtc off
    pass pm
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    thx, but i think simple dtc off not help while car go poor, dont have power, only from 2000rpm
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    And what gives that limp mode maybe dtc?
    What do you think about repairing the damaged wiring?
  8. The Following User Says Thank You to oldford For This Useful Post:
    bobolin4o (2nd September, 2015)
