Results 1 to 6 of 6
    Dec 2009
    Default HELP PROGRAMMING MAC7131 TIPM
    Hi.
    Im trying to clone an existing Chrysler TIPM (Totally Integrated Power Module) into a donor used one.
    Im using an XPROG and I can read both modules successfully but when I try to program the data, half of it is well written but the second half is bad programed, no matter how many times I try.
    But When I try to restore the data to its original state... the programming performs correctly.
    I mean, the MCU seems to accept only its old original data, but not a new one.
    Do you know if Im missing something... These two modules have the same part number so I dont want to change the flash, only the data... but is it necessary to change the flash also? any way to blank it?
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    your freescale mcu are with security byt activated !
    read flash and shadow area and save it,if already you have same it just Erase your mcu and first you have write the flash and after the shadow memory
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  3. The Following User Says Thank You to mihaiservice For This Useful Post:
    vict.guez (31st August, 2015)
    Feb 2010
    Any luck with this?
    Sep 2019
    Quote Originally Posted by mihaiservice View Post
    YEAP! It did work for me as mihaiservice said! Thank you, appreciated it!
  6. #5
    Jan 2019
    chile
    do you guys have the pinout for upa ?
    If I was helpful DONT forget the THANKS and REPbutton
  7. #6
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    here is pinout
    If i Helped you,use thanks and rep button to thank me back
