What kind of error code you have?
Hello , I need to delete my fap 1.3cdti opel 2008, ecu magneti mareli.
ECU MM OPEL MERIVA ORI.rar
Thank you in advance
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
brad123 (30th August, 2015)
The error code is abnormal particle filter pressure , at least I do not exactly remember me from my code that's on abnormal pressure problem fap, I did reading the ECU with a 1260 galletto its wrong?
Read galletto v48-54 or Kess
not possible with the dump that I post ?
no
need good file 2Mb
100% tested and working solution by me write me PM OR
100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
