100% tested and working solution by me write me PM OR
100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
m_yura (2nd September, 2015)
Theze mate all sensors need stay connected.Pass pm
thank
the remaining errors 2633
need help in removing EGR-off
try and report passw PM
disconnect connector from temperatur sensof and sensor diff.pressure + disconnect connector from EGR
Best regards Eddy
m_yura (4th September, 2015)
