Hybrid View
    Jul 2015
    Default help regrds Easy tronic Vectra C
    Hello :-
    please if any buddy can Help me
    My easy tronic MTA 33 module for Vectra C is get bad and I buy used module for Astra H it looks the same but when i connect it in my car is no communication After that i checked the dump files for AM29F400 and 24c16 and compared with vectra C dumps I found the same Eeprom but i found some difference in dump so I reprogrammed the AM29F400 and 24c16 for Astra H Same Vectra C AM29F400 and 24c16 but still no communication can any buddy help me for this issue .
    u sure module was bad? does it get voltage supply?
    Jul 2015
    it posible to use Astra H Easytronic module in Vectra c .
    hello ... i face the same problem... have you find solution to your problem...
    Aug 2011
    Spalding
    How about you go into the scan tool as an Astra H instead of a Vectra?
    Jul 2015
    the problem it's not working with the ecu for vectra that mean the vehicle not start
