You need to make immo off in eeprom and dash warnings disappear.
hi
i changed ecu with another identical ecu (same HW vag, same HW bosch, same SW bosch).
i need (maybe) immo off for this ecu in object, i try the "classic" immo off, car work but have some info on dash : immobilizer key, blink glow plug and esp.
i have all two ecu's backup, anyone have solution?
ok, can anyone do immo off in e2p?
I can do it in epp and clone ecu
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
ok, send me pm with mail or skype contact, thanks
Attach your files
here are complete backup, i need only immo off on e2p + checksum
GOLF 6 2.0 TDI 170 CV 03L906022LC_6175_0281015988_1037505936.zip
Attach also the old ecu backup
this is original ecu backup
GOLF 6 2.0 TDI 170 CV 03L906022LC_6175_0281015988_1037505936 OLD.zip
Next time post in immo or locksmith section. Just write this e2 to ecu. All data are from old ecu.
i did not know, sorry
i need only write this file on ecu? i must write also flash with immo off or flash simply as i read from used ecu?
many thanks
You need to flash in new ecu the original file it came with, and the eeprom the mate gave you. No need to immo off in flash. But i guess he cloned old ecu in new, not immo off.
ok tomorrow i write original flash of this ecu without immo off
I mean that in immo/locksmith section you get reply faster on your question. You need just write new eeprom to orginal new ecu and it should work like old(all important immo data are already inside from old). Probably it will work with immo off in flash too but better to stay orginal as much is possible.
morgano (3rd September, 2015)
i wrote original flash from used ecu, the dtc now are 1 and not 3 with blink glow plug
any solution?
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LC HW: 03L 906 022 G
Component and/or Version: R4 2,0L EDC 0000SG 6175
Software Coding: 0001072
Work Shop Code: WSC 01357 011 00200
VCID: 71E93346680917966BD-8024
1 Fault Found:
001552 - Engine Control Unit Incorrectly Coded
P0610 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162015 km
Time Indication: 0
Date: 2063.14.17
Time: 00:03:59
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Voltage: 12.24 V
Voltage: 12.24 V
Voltage: 12.24 V
Readiness: 0 0 0 0 1
