Results 1 to 4 of 4
    Default 2009 Insignia - DPF problem
    Guys,
    Have problem with 2006 insignia 2.0d , after when the dpf was removed car going in to the limp mode once weekley.
    There is no faults at all and only after dpf sensor reset car start driving ok...
    can some one please check my file, heard that my kess didnt read enough data and for proper job need to be use ktag....can someone confirm that? Attached ori and dpf off file.
    thanks in advance for help
    Nov 2012
    Hi cheester, i think is not possible DPF OFF if not are a Full Readout...
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Quote Originally Posted by cheester View Post
    Guys,
    your kess are ok if can read/write the file,the problem are from dpf off file
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Nov 2013
    UK
    Kess read only has maps and not full readout... that is why.
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
