Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 53
  1. #16
    Moderator
    PremierD's Avatar
    Jun 2009
    You should have listened you plank
  2. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    ASEK (13th September, 2015), digicon (13th September, 2015), gmb45 (13th September, 2015), Johnner (13th September, 2015)
  3. #17
    Sep 2008
    ahh hell went for breakfast and missed the fun as my pc was downnumber engaged
  4. #18
    Jun 2010
    still many missing, specially Asians. done factory reset still no joy.
  5. #19
    Feb 2010
    Asian channels are of at this time no amount of rescanning will bring them back.
  6. #20
    Jun 2010
    thanks asek, I thought it was my box.
  7. #21
    May 2010
    Channels down in liverpool from yesterday..
  8. #22
    Jun 2013
    Wolverhampton
    Pretty poor with glitching at the moment in Wolverhampton
    The Truth is out there ..........
  9. #23
    May 2010
    Back on in liverpool.....
  10. #24
    Jun 2013
    Wolverhampton
    On in Wolverhampton but very glitchy ! Not moaning , I know the lads will sort it
  11. #25
    Jan 2011
    All down for me today on Teesside.
  12. #26
    Sep 2008
    are you sure there down quiet elsewhere.does box and router need a reboot or local issues posted?
  13. #27
    Jan 2011
    Quote Originally Posted by cactikid View Post
    Thanks for the reply, I had it plugged into my second router which is running Openvpn, when I plug it back into my main router it works again. No idea what happened as it worked that way up until recently.
  14. #28
    Jan 2011
    Tried the second router without Openvpn running, firewall off, default. It won't let the Kryptview box communicate whatever, the other devices connected have net access, can't figure out what is blocking it. It isn't the VPN or firewall, I am stumped. Tried a different port, no change. Must use it on my ISP provided router to use it now, is this traffic suspicious?
  15. #29
    Jan 2011
    Fixed the bugger. I had a DDWRT nvrambak file stashed from when it was working as it should and used that, the result, it is now functioning perfectly. Be prepared, I was but had forgotten I had the file.
  16. The Following User Says Thank You to ChaLeeBoy For This Useful Post:
    cactikid (30th September, 2015)
  17. #30
    Newbie davedarave's Avatar
    Jan 2015
    Only seem to be getting Radio Foyle after a re-scan??? Glasgow area. Is this a local problem? Just my problem??
