Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 78
Thread: Silverado Help
  1. #16
    neospeedo's Avatar
    Garage
    i can honestly say that some boards are not rebuildable, just good to save parts
    - Remember Don't Just Sit There In Boredom, Add to the Forum!!
  2. #17
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by Relentless View Post
    I do have another question. Before I got the cluster I have now, I bought one that didn't work and I thought it needed the resistors to the right of the gear display to be resoldered because I had to do that to my original cluster. However, it didn't change anything, nothing works except the back lights. Any ideas?
    Good luck.
  3. The Following User Says Thank You to clusters For This Useful Post:
    Relentless (11th September, 2015)
  4. #18
    Sep 2015
    I did reflow all of the resistors(is that what they really are? I'm not privy on electrical components) But I did not do the little red coils, I will give that a shot. Thank you guys, you're awesome!
  5. #19
    Sep 2015
    Quote Originally Posted by neospeedo View Post
    if you have a working board in your truck why go back to the non-working board?
    I thought about selling it to offset some of the cost of buying the things to change the mileage in my IPC now.
  6. #20
    neospeedo's Avatar
    Garage
    sounds like a good idea! Try performing those repairs just remember that if it doesn't work after that, then you might as well consider it not rebuildable unless you have a speedo shop close by that can recheck it for you. But then again, that may in most cases be an extra charge.
  7. The Following 2 Users Say Thank You to neospeedo For This Useful Post:
    DashProg (18th September, 2015), zckariya70 (18th September, 2015)
  8. #21
    Sep 2015
    Should I just use a GQ4X for the mileage?
  9. #22
    Sep 2015
    Well, I did get a gq4x and I used tachosoft to tell me what data to change and when I try to enter 191,256 miles into the eeprom according to what tachosoft says, the cluster displays 118,860. I've figured out a lot by reading and trial and error with this but I don't know what to do now
  10. #23
    clusters's Avatar
    Mar 2015
    Canada
    1D 2E is around 191245 miles. Look closer at the TS calculation window, you should be able to figure it out.
    I'll bet you used 12 22.
  11. The Following User Says Thank You to clusters For This Useful Post:
    Relentless (18th September, 2015)
  12. #24
    neospeedo's Avatar
    Garage
    191256 Kilometers = 118840.969 Miles. Try 307796 and u will get 191256 miles Tacho is giving u results in KM.
  13. The Following User Says Thank You to neospeedo For This Useful Post:
  14. #25
    Sep 2015
    Quote Originally Posted by clusters View Post
    Yes, I did use 1222, I saw that it was in kilometers but I thought that it didn't matter because it was just a number, haha, guess that's what I get for assuming.
  15. #26
    neospeedo's Avatar
    Garage
    If you want to do hours, look under Chevrolet Tahoe in tachosoft
    Work hours are stored in next lines:0050: xx xx xx xx 0C 5D xx xx xx xx xx xx xx xx xx xx
  16. #27
    clusters's Avatar
    Mar 2015
    Canada
    Hummer H2 in TS will calculate the hours properly for all 2003-2006 GMT800 trucks.
    Unless it's over a certain number of hrs, then there is another location to correct.
  17. #28
    Sep 2015
    It worked! You've both been a tremendous help through this, I appreciate it a lot. Once I figure out this programming deal I'm not sure what I'll move onto next haha
  18. The Following 2 Users Say Thank You to Relentless For This Useful Post:
    clusters (18th September, 2015), neospeedo (18th September, 2015)
  19. #29
    Sep 2015
    So, I repaired the cluster I had that way blacked out, it was the little red coils needing reflowed! I was running it in my truck just as kind of a test to make sure it wasn't going to have any issues. Now, it seems like it's draining my battery, I googled it and it seems to be a rather common problem. How many issues can these things possibly have! This is nuts
    Also, is there a way to donate to the site? I appreciate all of the help i've gotten, I would like to contribute
  20. #30
    clusters's Avatar
    Mar 2015
    Canada
    Cool..........................
  21. The Following User Says Thank You to clusters For This Useful Post:
    Relentless (22nd September, 2015)
