Results 1 to 4 of 4
    Default Ford C.Max 2.0 Tdci 136 SID803 EGR problem
    Hi, I have a Ford C-Max 2.0 Tdci 136 MY 2004 SID803.
    I change 3 times EGR Valve, but no more.
    It have DTC P0490.
    Could please somebody remove EGR and all EGR DTCs Off, P0490 and P0401 to P0409
    mihaiservice's Avatar
    http://www.quick-tuning.com
    If that car are equipped with dpf than the problem are from dpf !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Quote Originally Posted by mihaiservice View Post
    It hasn?t Dpf. The problem is only EGR.
    Out side world
    You need to ensure that the EGR is closed and then disconnect the cable
    egr_dtc_Cmax 2.rar
  5. The Following User Says Thank You to franke232 For This Useful Post:
    vallinet (14th September, 2015)
